Activity Forums Adobe Premiere Pro Premiere Pro 1.5 won’t run on new system
  • Premiere Pro 1.5 won’t run on new system
    Posted by Blabbaboo on October 28, 2006 at 8:59 pm
    Hi, I was running 1.5 on an AMD 1700 cpu with 512 RAM, and a Geforce video card w/256 ram, and it worked well. Now I’ve upgraded to a dual core AMD with 2009 each side, 1 gig of ram, and onboard Geforce 6150 w/256 ram. I was on XP Pro, now on XP Media Center, and after installing Premiere Pro 1.5, the pc reboots every time I try to start Premiere. Is there an obvious problem I’ve overlooked, or some optimization I could do to remedy this? I can’t use my old Geforce card because it’s AGP, and my new pc uses PCI Plus. Any help appreciated. Thanks.
    Blabbaboo replied 19 years, 10 months ago 4 Members · 6 Replies
  • Aanarav Sareen
    October 29, 2006 at 3:49 am
    Is that an HP PC by any chance? What is the audio card? Is it Realtek?
  • Blabbaboo
    October 29, 2006 at 4:02 am
    It’s a Gateway GT5220, and I just ordered a PCI Express 256 ram video card. I’m sure that will fix the problem, but thanks for the response.
  • Thompson
    November 3, 2006 at 1:12 am
    Aanarav Sareen,
    I built a new system and the motherboard has onboard RealTek sound card. I’m having terrible problems with rendering the footage on the new system with 1.5.
    Could that be related to my sound card?
    thanks,
  • Blabbaboo
    November 3, 2006 at 5:11 pm
    I installed a GeForce 7300 GS video card, but still reboots when trying to start Premiere Pro. Now I don’t know what to do, I was sure a good video card would do the trick. Any ideas? Thanks for the help.
  • Garybb
    November 9, 2006 at 9:52 pm
    I have a brand new gateway 4204 and I get the exact problem with Premiere 1.5 and 2.0 The PC will reboot and that is it. This gateway uses a Realtek sound card. That is the only thing I can think of that could be causing a conflict. My prior PC was an HP and my premiere ran fine. Gateway tech support has no suggestions…Can anyone please provide some guidance as to what is going on?
  • Blabbaboo
    November 10, 2006 at 9:08 pm
    I found the fix on Adobe’s site. You have to update the driver for your Realtek audio, and Premiere Pro 1.5 and 2.0 work fine, no reboots.
