Activity › Forums › Adobe Premiere Pro › Premiere Pro 1.5 Freezes during capture
Posted by Beatlefan on June 30, 2005 at 9:33 pmI
Beatlefan replied 21 years, 2 months ago 3 Members · 4 Replies -
Scott
July 1, 2005 at 1:04 amIt sounds like a firewire briver issue. Try downloading the latest driver version and see if that helps. Also, disable windows from accessing the firewire port for networking (in networking properties page.)
If that does not help let us know.
Scott
R. Hewitt
July 1, 2005 at 10:00 amAs Scott says, most likely to be a Firewire issue although some antivirus applications performing realtime scanning can cause this – in my case Norton was the culprit.
It’s possible that another application is grabbing the port for its own use. Make sure there are no video editing applications in your Windows startup folder.
Beatlefan
July 1, 2005 at 2:42 pmI did not find any sign of video editing apps in the start up folder I updated the Firewire drivers and updated the drivers for the Soundblaster Audigy card, which has the port that I am connecting the camera to. Also, I did find that I had a 1394 port enabled for networking. So I have disabled that port in the properties page as well as unchecked the options for:
Client for MS networks
File and Print sharing
Internet Protocol TCP/IPIt still crashes!
Beatlefan
July 1, 2005 at 4:22 pmStill Crashing! Anyone have an idea as to what is making it happen?
