Activity › Forums › Adobe Premiere Pro › Premiere Pro 1.5 cannot capture from Panasonic PV-GS250
  • Premiere Pro 1.5 cannot capture from Panasonic PV-GS250
    Posted by Delfino on September 21, 2005 at 3:50 pm
    I posted this similar issue at the Adobe forum. My problem is that Premiere Pro 1.5 does not recognize my Panasonic PV-GS250 via firewire (1394). I have XP Pro with SP2. As soon as I turn on the camcorder during capture, XP freezes and then reboots. I have disabled the 1394 connection in Network Connection. I can
    Delfino replied 21 years ago 2 Members · 5 Replies
  • Mike Velte
    September 21, 2005 at 7:27 pm
    Suspect that either Nero of Roxio have overwritten a system file like qcap.dll (my version is 6.5.1.900 a Microsoft version). What is your version?
  • Delfino
    September 21, 2005 at 7:33 pm
    Mike,
    Thanks for the reply. I was already having this problem when I only have XP Pro and Premiere Pro 1.5 installed plus the basic drivers on the XP Pro’s default install.
    I will check tonight to see my gcap version. I am at work right now.
    Delfino
  • Delfino
    September 22, 2005 at 2:25 am
    Mine is 6.5.2600.2180. I have search the Internet, and from what I gathered the qcap.dll is the Microsoft Codec. Some suggested to switch this codec with a Mainconcept codec. I am not excited on replacing what I have with yours. I already reinstalled XP six times the last two weeks trying to troubleshoot this issue.
  • Mike Velte
    September 22, 2005 at 11:39 am
    Try expirementing with settings for your camera’s model/make; Edit>Preferences>Device Control>Options>Device Type and Brand.
  • Delfino
    September 22, 2005 at 3:27 pm
    Thanks Mike. I did try every model for Panasonic and others. Same results. BTW, I used my Canopus ADVC-50 last night to capture old VHS tape. I was able to use the Premiere capture. I was never able to use the capture software to control the VCR. I have to manually start-stop the VCR. But I am happy with that, at least it works.
    Now for the Panasonic issue, my theories are that the 1394 controller in my Intel 915PBL motherboard have compatability issue with Premiere 1394 driver, Panasonic and Premiere also have some compatibility problem.
    There is another thread that report of the same issue I have, that is, the Premiere freezes and reboots after running the capture. The only difference is that he said this has never happened before.
