Activity Forums Adobe Premiere Pro Premiere Pixellating Pro Res Titles on Export???
  • Premiere Pixellating Pro Res Titles on Export???
    Posted by Nick Ralf on February 12, 2021 at 1:30 pm
    Really weird situation I have not come across in Prem before. I have a few Pro Res 4444 on Alpha titles that are rendered at 4k on a 5k timeline. They look fine in the viewer, but come out looking like they are 280p or something on my exports. The video is fine and correct, it’s just the titles. I have tried the AE comps direct on the timeline and get the same issue. Horrible pixelated titles.
    Any ideas as its really throwing me?
    PS. I’m on an iMac Pro, Big Sur and the latest version of Prem…
    Tim Kolb replied 5 years, 7 months ago 3 Members · 5 Replies
  • Tim Kolb
    February 13, 2021 at 3:34 pm
    What did the PR444 files come from? AE?
  • Tim Kolb
    February 13, 2021 at 4:32 pm
    Sorry…I should have read less hastily…clearly they came from AE.
    You said you have a ‘few’…are there others that are coming through fine on export, or are all the PR444 titles in that project messed up?
    Have you used this exact workflow in the past without issue?
    Not that these are sure fixes, but have you tried importing that project into a new/clean project just to see if it affects the problem? (Just troubleshooting here…nothing jumps out at me…
  • Nick Ralf
    February 18, 2021 at 9:43 am
    Thanks so much Tim… I’ve used this workflow a hundred times without any issue before. No major changes to my system either.
    If I export my Timeline and re apply them in another sequence it seems to cure it – but cant understand why something in my sequence setting is making sure any onscreen graphic comes out at 1/16th of the resolution of the rest of the video. Maybe I have missed something obvious, or its just a bug – not sure?
  • David Baud
    February 19, 2021 at 9:42 pm
    I would delete the media preview and caches files. That should fix your problem.
  • Tim Kolb
    February 19, 2021 at 11:47 pm
    It sounds like the problem is tied to the specific sequence. If you just copy the entirety of the content and make a fresh sequence and paste it in…does it still demonstrate the problem?
