Activity Forums Adobe Premiere Pro Premiere not working on my Mac Logon
  • Premiere not working on my Mac Logon
    Posted by Dan Phillips on February 17, 2012 at 10:41 pm
    Our team has several community Macs running Premiere. We all use our own logons when we work on the computers. We recently upgraded to OS Lion and CS 5.5. When we did Premiere would only work on the logon on which it was installed. It will start to open on other logons but then just disappears. Anyone else experiencing this or know of a solution.
    John Reed replied 13 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Petros Kolyvas
    February 18, 2012 at 6:31 am
    I shared some info in another thread where something like this happened. We had to delete the account in question and create a new user account. When trying to delete the account, we also tried to “archive” the account’s contents (settings, etc.) and it failed, indicating, in part, the account itself had become corrupt.
    Once a new user account (with the same username/password) was created, all was well.
    We now believe the issue was cause when Premiere was open on one user account while Fast User Switching was used to access something in another account and Premiere was opened accidentally. The non-admin account (admin account was used to install Production Premium) would be unable to use Premiere even though it worked fine on the primary admin account.
    Hope this helps!
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Dan Phillips
    February 20, 2012 at 4:20 pm
    Thanks for the input. Tried it but it did not work. However, have since discovered that the issue is with the Squeeze Plugin for Premiere.
  • John Reed
    November 28, 2012 at 6:05 pm
    Hey Dan,
    Im having the same problem – I just installed Squeeze 6.
    What did you do to solve it? Thanks for your help
  • Dan Phillips
    November 28, 2012 at 6:34 pm
    Uninstalled Squeeze.
  • John Reed
    November 28, 2012 at 6:41 pm
    I uninstalled squeeze
    at least I think I did it right
    I deactivated it and then put the squeeze folder in teh trash, and emptied the trash
    it still says
    Adobe Premiere Pro CS5.5 quit unexpectedly.
    any other ideas or did I miss something
    thanks again
  • Dan Phillips
    November 28, 2012 at 6:44 pm
    It is possible there is a squeeze plugin in the premire plugins folder. Get rid of that.
  • John Reed
    November 28, 2012 at 7:34 pm
    there isnt a plugins folder in premier pro but when I did a search for one it shows a ” Squeeze.as in Dream weaver and squeeze.ffx in after effects. I deleted the squeeze files but still says “Adobe Premiere Pro CS5.5 quit unexpectedly. any ideas and again appreciate your help
