Activity Forums Adobe Premiere Pro Premiere needlessly wants to render my timeline!
  • Premiere needlessly wants to render my timeline!
    Posted by John Kis on December 16, 2008 at 11:56 pm
    Great forum guys. Really helpful stuff…
    I’m importing NTSC DV footage into my NTSC DV project and when I put the footage on the timeline it immediately appears with a red line above it. I’ve checked the size of the frame (720 x 480), the frame rate 29.97 and the compression of the source footage – yes, DV! (I tried both the Panasonic DV encoder and also the Mainconcept DV encoder in VirtualDub to create the files I imported into Premiere)
    I haven’t applied ANY effects to the footage.
    I’ve tried interpreting the footage to every available aspect ratio option – no cigar.
    I’ve even tried setting the editing mode up as “desktop” and selecting “mainconcept” as my preferred compressor in the project settings. Nope!
    One odd thing I have noticed is that ‘frame blending’ is automatically selected in the clips on the timeline. When I turn this off it doesn’t change the rendering status.
    Video captured with Premiere works fine.
    I’d love to hear some suggestions…
    John Kis replied 17 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Eddie Lotter
    December 17, 2008 at 2:43 pm
    It seems there is something that is making PPro think the file is not DV compliant.
    Use a utility like GSpot to interrogate the file for problems. Post the results.
    Cheers
    Eddie
  • John Kis
    December 18, 2008 at 12:10 am
    Thanks for suggesting the line of enquiry. I’ve uploaded the image of the GSpot analysis.
    Do you think it’s got anything to do with whether the DV file is type 1 or type 2?
  • Eddie Lotter
    December 18, 2008 at 2:47 pm
    Type 2 is good (Type 1 requires rendering) but Dolby audio is not standard DV and therein lies your problem.
    Cheers
    Eddie
  • John Kis
    December 18, 2008 at 10:52 pm
    Thanks Eddie. I really appreciate your assistance.
    John
  • Eddie Lotter
    December 19, 2008 at 8:51 pm
    You’re welcome. Happy editing. Happy editor
    Cheers
    Eddie
  • Kim Huston
    January 29, 2009 at 9:14 am
    I have this exact same question, but with a different codec and no audio.
    I’ve got an Apple Animation file I exported from After Effects that wants me to render in Premiere in a project of the same specs as the file.
    I used the analyzer and all it said was this:
    File
    size: 6.35 GB (6,506 MB / 6,662,616 KB / 6,822,519,487 bytes)
    Container
    qt : Apple QuickTime (.MOV/QT)
    File Type: QuickTime (.MOV)
    Mime Type: video/quicktime
    And then there was a button lit up at the bottom uder “MS A/V” and when I clicked it, it said this:
    “Rendering failed. Following is the error reported by DirectShow:
    0x80040265: [unknown]”
    It’s really frustrating because I’m exporting at a high resolution out of After Effects, and then Premiere comes along and ruins the quality by rendering it 🙁
  • John Kis
    February 2, 2009 at 10:58 pm
    Hi Kim,
    What ‘editing mode’ are you in (project/project settings/general)?
    John
