Activity Forums Adobe Premiere Pro Premiere keeps crashing after installing BCC Continuum Complete
  • Premiere keeps crashing after installing BCC Continuum Complete
    Posted by Alina Shupikova on November 17, 2013 at 11:11 pm
    I have a problem I can`t really work around. I need to remove flickering from the footage and am using the BCC Flickering Filter in Adobe Premiere Pro CC. It works, I even managed to export the footage a couple times. But now there is a repetitive problem – Premiere pro “quits unexpectedly” a couple minutes/seconds after I use the filter and Adobe Media Encoder does the same when I try to export the footage.
    May I ask for help in finging out what is wrong and fixing it?
    Thank you in advance!
    Alina
    Kuhnen Brown replied 12 years, 9 months ago 2 Members · 1 Reply
  • Kuhnen Brown
    November 18, 2013 at 8:40 am
    When installing BCC it looks for Premiere. Did you use the newest BCC installer for Adobe CC? Another test… are you crashing when using the same BCC plug-in with AE?
