Activity Forums Adobe Premiere Pro Premiere JPG – batch import – bug
  • Premiere JPG – batch import – bug
    Posted by Dennis Noel gomez on October 12, 2015 at 11:30 pm
    Hi Guys,
    I’m using a PC running Windows 7 Professional with Premiere CC 2015.
    Through the Premiere File>Import function, I’m tyring to import several JPG images (1920 x 1080 @ 72dpi resolution) – exported out from Illustrator – around 600-800kb size.
    What happens is that once I import the images, they are all the SAME image, even though I selected all different images.
    No matter how many times I import a different image, it still imports the same image.
    When I import the images one by one, it still doesn’t work.
    I’ve restarted my computer, restarted premiere, but no luck.
    I’ve found a temporary work around, by using PNG files, Premiere seems to accept them.
    Has anyone else encountered this bug before? Do you know the solution?
    Dennis
    Dennis Noel Gomez
    Video Editor
    Motion Graphics Designer
    Take One Productions
    Dennis Noel gomez replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
