Activity Forums Adobe Premiere Pro Premiere is not correctly playing audio files
  • Premiere is not correctly playing audio files
    Posted by Josh Peters on May 24, 2012 at 10:27 pm
    This is sort of an odd issue, but premiere lately has simply been incorrectly playing audio files. I will import something in this case a music track in .aif and it will seem fine but randomly it will just stop playing correctly. The waveforms display properly but the actual audio is not representative of the file. It just skips around and does bizarre things. I’ve tried reimporting etc but it seems that once it decides it doesn’t like a file it just won’t return to reading it properly. Is this common?
    Mark Wilson replied 14 years, 3 months ago 3 Members · 2 Replies
  • Chris Mckechnie
    May 24, 2012 at 11:22 pm
    I experience it as well…just hitting pause then play again generally fixes the issue. Hope Adobe fixes this little known bug.
  • Mark Wilson
    May 25, 2012 at 4:03 am
    I had a similar problem, the audio started playing on the empty part of the track. I have a one minute gap between two aiff files on the same track, it would start playing the first file during the gap. I had to use the mute automation in between files.
