Activity Forums Adobe Premiere Pro premiere is exporting postage stamp-size video files, please help
  • premiere is exporting postage stamp-size video files, please help
    Posted by Y2keable on December 7, 2006 at 2:57 pm
    Hi. i just obtained pro 7.0 and i think its great. i have no problems with making movies but when i export the project to a file, the image is really small. no matter what file type i specify or what frame size i input, which encoder i use, weather i select PAL or NTSC, what preset filesize i select…
    here’s an example:
    video link
    I’ve tried both “export to movie” and the “export to adobe media encoder” paths and i always get the same result, a video no bigger than a postage stamp. any sugestions as to how i can get premiere to render full screen videos?
    best regards
    Jayson
    Steven L. gotz replied 19 years, 9 months ago 6 Members · 12 Replies
  • 12 Replies
  • Steven L. gotz
    December 7, 2006 at 7:08 pm
    What kind of camera are you using and how are you capturing the video? It looks like you are starting out to small to begin with.
    Steven
    https://www.stevengotz.com
  • Blast1
    December 7, 2006 at 7:16 pm
    [y2keable] “how i can get premiere to render full screen videos?”
    Viewed on what?
  • Y2keable
    December 7, 2006 at 7:43 pm
    i’ve been using the AVI files from my Pentax S50 (320×240) which are stored on my hard drive. i import these files to premiere and they edit up nicely. i can play one of these AVI files (straight from the camera) in any of my media players and it fills the screen nicely but once its been imported into premiere then exported, the video seems no larger than the thumbnail. even if i put the media player in full screen mode, id dosen’t get bigger =/
    one thing i’ve done since posting my question is import a veriaty of high quality videos into premiere (some at 1280×960) and it still exports a video with the same postage stamp size dimentions.
    thanks for the help
    Jayson
  • Y2keable
    December 7, 2006 at 7:47 pm
    i’m using windows media player and real player to view the exported files
  • Harm Millaard
    December 7, 2006 at 8:02 pm
    You ever heard the statement: “Garbage in, garbage out” ? This is a typical example of GIGO. If you input a small frame size in a format not meant for editing, how can you expect to get good results? Accept the fact that this material was NOT meant for editing, at least not with this kind of application. Either get a good DV or HDV camera or a different application.
    Harm Millaard
  • Y2keable
    December 7, 2006 at 8:22 pm
    thanks Millaard
    like i said, i’ve also used footage form a friends vedio collection which is quite good quality and i’m still getting the same problem. as for GIGO, i can understand putting 320×240 in and getting 320×240 out but i’ve even been putting 1280×960 in and still getting a postage stamp out (which looks something like 160×120)
  • Craig Howard
    December 7, 2006 at 9:45 pm
    What project preset are you using ?
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    Premiere Pro 2.0
  • Y2keable
    December 7, 2006 at 9:51 pm
    i’ve used them all, including lots of different combinations of custom settings but usually go for DV PAL standard 23kHz
    regards
    Jayson
  • Steven L. gotz
    December 7, 2006 at 10:13 pm
    If you put a small 320X240 clip into a 720X576 frame, which is standard for PAL, you will get a postage stamp out. You must either create a custom project with a 320X240 frame size, or you must scale up the video to fit the larger frame before you export back out to 320X240.
    Steven
  • Y2keable
    December 7, 2006 at 11:52 pm
    of corse, its so simple =)
    problem solved, many thanks for the help
    Jayson
