Activity Forums Adobe Premiere Pro Premiere is exporting .mp4 with wrong fps
  • Premiere is exporting .mp4 with wrong fps
    Posted by Aira Vehaskari on April 16, 2014 at 7:12 am
    Hello,
    For some reason, in the past few days I can’t get Premiere to export my video as .mp4 with the correct fps. The material was shot in 1920/25p, the sequence settings match the source. In the Export media window, I have definitely selected 25 fps and progressive for my .mp4, and the Media Encoder window confirms this. But the exported video is bizarrely 25.59 fps. My colleague has watched me do this and is also stumped. We’ve tried a dozen times.
    I’ve successfully exported this project in the past week without problems to show my client drafts – albeit at a lower resolution, so I can post it online for him to see. Also, I’ve tried exporting bits and pieces of it – 10 seconds here and there – and it turns out ok. When I export it as .mov, it comes out fine. But not .mp4. This problem has only appeared in the past few days.
    I’m using CS5 (yeah I know, I just haven’t reached critical mass to upgrade to CC) on a Mac. I’ve double-checked the source files, the camera settings, the sequence settings, the export settings. Nothing is out of order, everything looks completely normal.
    any help?
    cheers,
    Aira
    Anna Berg replied 10 years, 12 months ago 3 Members · 2 Replies
  • June Stathis
    August 14, 2014 at 4:25 am
    I have been having exactly the same issues as you. So you are not alone here!
    I am using CS6… I’ve tried everything without succeed.
    I am stumped as you are.
    I was hoping to find answer here but no one replied, bugger!
    I will continue to find a way to get this working, once I have figured out… I’ll reply here! And hope you would do the same.
    Cheers
    eyethian
  • Anna Berg
    September 24, 2015 at 4:04 pm
    I had the same issue as you guys.. Premiere cc 2015 suddenly only exported 22.99 fps .mov when i tried to export at 25 fps. Previously exporting was working well with the same sequence.
    I managed to find a work around: exporting a dnxhd .mxf file resulted in a 25 fps file.
    Did you manage to sort things out?
