Activity Forums VEGAS Pro Premiere into vegas?
  • Premiere into vegas?
    Posted by Adam Rose esq. on October 3, 2006 at 7:41 pm
    client has given me drive of raw avi used in original Premiere edit (can’t remember if PPro or 6.5 etc), and I need to edit it further
    any easy method of getting EDL from Premiere into vegas? He said he didn’t know of a way to export the EDL at all, and I have no experience using PPro
    thanks
    Adam Rose esq. replied 19 years, 10 months ago 4 Members · 4 Replies
  • Donatello
    October 3, 2006 at 9:17 pm
    ask the premiere thread how to export a EDL or AAF ..
  • Dr. Dropout
    October 4, 2006 at 12:59 am
    AAF from Premiere Pro opened in Vegas 6/7 should work pretty well. Pre-“pro” premiere lists/projects/exports of any type almost definitely will not open in Vegas correctly. If you are in 6.0x era Premiere, try opening the project in (ideally the current version of) Premiere and then export to AAF. Vegas 6 or 7 should open that AAF.
  • Timothy Duncan
    October 4, 2006 at 1:09 am
    You may have to do some manual “cleaning” of the PPro project first. Don’t use any subclips in PPro (go back and replace with original master clips) and also don’t allow any “nesting” of PPro sequences. If there is any nesting — Vegas will import the clips into the project, but not give you anything on the timeline. Multiple sequences will come into Vegas as separately labeled layers.
    I go to/from PPro and Vegas fairly regularly. I have one client that offlines in PPro and I then import to Veags for online via AAF. And — I also offline in Vegas and AAF to PPro/Axio for uncompressed work.
    td
  • Adam Rose esq.
    October 4, 2006 at 8:37 am
    thanks all for the help. posted question in PPro forum as suggested but no response yet, but this is perfect
    cheers
