Activity Forums Adobe After Effects Premiere into AE audio woes
  • Premiere into AE audio woes
    Posted by David May on May 25, 2008 at 1:18 pm
    Hi all.
    If i set my premiere project audio levels/volumes/effects just how i want them, import into AE and dont touch them, and render from AE my final product, should I have any changes to the audio?
    My reason for asking is that I am using AE 7.0 with the magic bullet looks suite (couldnt get it to work with CS3) and CS3 Premiere wont recognize it (the looks suite) if I save my AE project for premiere. The only solution I can see to this is have a more or less finished product to put through AE, as i wont be able to fiddle with my audio etc when its done.
    This means i will need to have the spaces for my credits etc set aside or ill change the length of my comp, and throw off the audio levels.
    So if anyone knows if AE will leave my audio unchanged, or have any suggestions about working around my not going back to premiere once im done problem, id love the help.
    Cheers
    Dave
    (Thanks to Simon Bonner who’s been a huge help answering some similar questions)
    David May replied 18 years, 4 months ago 2 Members · 2 Replies
  • Simon Bonner
    May 25, 2008 at 6:26 pm
    Hi again,
    I, and I’m sure several others, would advise you not to output your audio from AE. It just doesn’t do a very good job. If you absolutely have to do it the way you describe, how about rendering video from AE as lossless avi / QT animation, then importing it back into Prem, lining it up with the preexisting audio, and making one final render.
    Simon Bonner
    youtube.com/simonsaysFX
  • David May
    May 25, 2008 at 10:27 pm
    Great suggestion! This work has taken me over 150 hours so far, so Im having a bit of trouble taking that step back and thinking of the best idea. Hopefully not having the audio in there will also speed up my working in AE, as its chugging along with the whole project.
    Ill get started on my effects, and without a doubt ill be back when i finish the effects with more questions on exporting.
    Thanks a lot mate 🙂
    Dave
