Activity › Forums › Adobe Premiere Pro › Premiere has problems with my AE animation
  • Premiere has problems with my AE animation
    Posted by Richard Scott on October 8, 2009 at 1:13 pm
    I have an After Effects animation that Premiere just doesn’t like. When I add it to my timeline Premiere will not export my sequence furthermore it makes the system shaky and unstable.
    Here is the kicker, I’ve re-rendered the AE movie over and over again in different codecs to see if there was an issue there but it doesn’t seem to matter.
    I can export the animation from AE in my Premiere sequence’s resolution so that premiere doesn’t have to render the clip or I can use a lossless codec from AE (i’m editing in DV 4:3) and let premiere render it out in the sequence’s codec and I still have the problem.
    I’ve rebooted, deleted renderfiles and re-rendered. I’ve done everything short of dumping the animation off to tape and recapturing it which I really don’t want to do because I don’t have an SDI output on my system and don’t want to take a hit in quality.
    I have the latest upgrades installed, I have a CS4 E5430 Xenon Quad Core processor with 3gigs of memory. My OS is XP with SP3.
    Any suggestions?
    Richard Scott replied 16 years, 11 months ago 3 Members · 4 Replies
  • Tim Kolb
    October 8, 2009 at 2:37 pm
    It’s possible the AE project has an issue I suppose…
    Can you make a new project? Maybe try importing the original project into it and rendering the comp that way.
    I can’t believe that if the AE renders are causing a problem that dynamic linking the AE comp to the PPro timeline would be better, but it’s worth a shot in the name of science I suppose…
    If that doesn’t work, you may want to try something from scratch in a fresh project…
    You can make a new project and drop a render from that in place and it’s OK, right?
    TimK,
    Director, Consultant
    Kolb Productions,
  • Richard Scott
    October 8, 2009 at 3:14 pm
    I’ve tried making new sequences, and new projects and every time I used that piece of AE animation or one of its many re-rendered versions I have problems.
    It was a complicated AE project and it would take a lot of time to rebuild so I’d rather not have to redo the comp if possible.
  • Jon Barrie
    October 8, 2009 at 11:24 pm
    What version of Quicktime do you have on your system? You may have to either update it or roll back a version. I have 7.5 on mine and that seems to have worked fine.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Richard Scott
    October 15, 2009 at 1:53 pm
    I am pretty sure my AE project was somehow corrupted but I found a work-around. I exported my animation as an uncompressed tiff sequence and re-imported the clip into a new AE project and rendered it out as a DV clip.
    Premiere worked with the new clip just fine.
