Activity Forums Adobe Premiere Pro premiere generates audio cracks
  • premiere generates audio cracks
    Posted by Jasper King on February 17, 2010 at 4:02 am
    I made a movie with premiere pro cs4, and discovered allot of cracks in it.
    The strange thing is, when i play the original dv pal avi video en listen to the audio track u cant hear any crack or pop sound in it.
    but when i load the avi into premiere and after it generates the peak file i can hear the cracks when i play the timelime.
    i also thought it had something to do with my audio drivers but when i look close to the wave file in the timeline, the cracks are really baked into the avi’s wave track.
    how do i get rid of this? and please be clear these cracks are NOT on the original video file.
    Here’s an example of a render where u can hear the audio stops every few seconds:
    https://www.youtube.com/watch?v=HcanefxEqvQ (8/9 sec : 18/19sec : 29/30sec : etc. etc.)
    My setup:
    Processor – 1 x Intel Core i7 i7-860 / 2.8 GHz – LGA1156 Socket – L3 8 MB
    Intel X25-M Mainstream Solid State Drive
    MSI P55-GD65 – ATX – iP55 – LGA1156 Socket – UDMA133, Serial ATA-300
    Samsung SpinPoint F3 Desktop Class HD103SJ – 1 TB
    SATA-300 – 7200 tpm -buffer: 32 MB
    Microsoft Windows 7 Ultimate 64x
    XFX Radeon HD 5870 1 GB GDDR5
    8gb of memory
    Audio driver using: M-Audio Fasttrack
    Other audio drivers but all give the same problems: Realtek HD & Asio4all
    Jasper King replied 16 years, 7 months ago 2 Members · 2 Replies
  • George Socka
    February 18, 2010 at 2:26 am
    I get the same with DV downconverted from HDV in a Sony V1U. Not sure where it comes from. If I log in small clips – 1 minute or so, and batch capure one clip at a time the problem generally goes away. Dont know if it is the Camera or the computer firewire port. Capturing the same video in HDV, the audio is beautiful. I have resorted to capturing in HDV and the opening those files in a DV project. I have never tried shooting in DV mode and then capturing that, ie eliminating the downconverting step at the time of capture. I dont want to accumulate any more DV footage though. I have also never tried capturing from another pure DV camera. Might do that.
    Now, I like small clips, but it means you need to babysit the system during batch capture.
    George Socka
    BeachDigital
    http://www.beachdigital.com
  • Jasper King
    February 18, 2010 at 8:36 pm
    but i dont have the problem when capturing, that is no problem and as i said.. when i play the raw avi file the audio sounds good.
    and i dont record on hdv but on DV 16×9 PAL, i will go check if short captures also have the same problem.
    Because now i use avi files off 9/11 gb.
