Activity › Forums › Adobe Premiere Pro › Premiere for keying C100 footage
  • Premiere for keying C100 footage
    Posted by Brad Bussé on February 7, 2014 at 11:10 pm
    I have a c100 on order for shooting primarily green screen footage using a Ninja 2 to record either 422 or HQ, probably in c-log. Has anyone had experience working with c100/c300/c500 footage in Premiere for keying? I’m hoping to ideally be able to setup an adjustment layer that other video artists can use which contains a keyer, a Lumetri LUT, and final corrections like sharpening.
    Paul Neumann replied 12 years, 7 months ago 2 Members · 1 Reply
  • Paul Neumann
    February 8, 2014 at 1:00 am
    I make .looks in Speedgrade for green screen footage and use them in PPro all the time. Just for balance and to push the green background levels. So, I’d start there. I have a preset of Garbage Matte, Ultra and RGB Curves that is my “go to” set up. I put the .look on first and then add those three. Season to taste. I’ve even put the .look downstream from the keyer and it still worked fine.
