Activity Forums Adobe Premiere Pro Premiere Export Stops at 9 seconds
  • Premiere Export Stops at 9 seconds
    Posted by Molly Blank on April 20, 2021 at 6:56 pm
    I have a 28 minute file that I am trying to export just as medium-bit rate H264 but every time I do it freezes when it has about 9 seconds left. I restarted my computer, deleted the render files related to the sequence, copied and pasted the sequence into a new sequence. I tried XML export to learn the problem and I got the below info about translation issues — I have replaced those bites (just by deleting them on the sequence and putting them back in) but still have the same issue. Can someone explain translation or help me? Have to get this to client ASAP! Thank you, Molly
    Translation issue:
    Sequence <For Export> at , audio track 1: Effect <Internal Channel Volume Stereo> on Clip <C0002.MP4> not translated.
    Translation issue:
    Sequence <For Export> at , audio track 1: Effect <Internal Channel Volume Stereo> on Clip <C0125.MP4> not translated.
    Molly Blank replied 5 years, 4 months ago 3 Members · 3 Replies
  • Eric Santiago
    April 22, 2021 at 2:24 pm
    Have you tried exporting as a ProRes or DNxHR file?
    Sorry I dont know your specs and target format.
  • Todd Perchert
    April 22, 2021 at 3:35 pm
    Try Eric’s suggestion first.
    And you’re editing mp4 files? Try transcoding those mp4 files to something like ProRes mov. Then re-edit the clip in. Then export.
  • Molly Blank
    April 22, 2021 at 10:02 pm
    Thank you both! I figured it out. I mean I had another copy of the same clip that wasn’t messed up so I used that one!
