Activity Forums Adobe Premiere Pro Premiere Elements – Breaking up a project
  • Premiere Elements – Breaking up a project
    Posted by Joe Landau on May 17, 2009 at 2:13 pm
    I am a novice.I have a large project and would like to simulate the “sequence” capability available in PP, to break up my project into sub-projects. What is the best way to do that? I am working with the AVCHD format (I found it easier to work with Elements then with PP!!), If I break it up into several projects, how do I put the whole thing together?
    Vincent Rosati replied 17 years, 3 months ago 2 Members · 1 Reply
  • Vincent Rosati
    May 18, 2009 at 1:45 pm
    I’m not sure, I haven’t used Elements. In Premiere, you could nest the sequences in a sort of master sequence – Create a new sequence/timeline and call it ‘Master’. Than, drop the other sequences into it.
    If you were making a DVD or something, you could encode each sequence, than have them run contiguously.
    Just a few thoughts
    Vince
