Activity › Forums › Boris FX › Premiere dropping frames and freezing
  • Premiere dropping frames and freezing
    Posted by Tara Walch on January 19, 2007 at 6:49 pm
    my program drops frames and freezes whether my video is freshly captured or rendered through after effects. my settings should be fine, same ones i’ve used in the past. i use digisuite to capture, i have windows 2000 service pack 2 and it is premiere 6.5.
    the error message is as follows:
    4 frames dropped during playback
    Received MQ_EVENT_INFO event:
    Category = 0 x 10005.
    Code = 0 x 4105C.
    Severity = 0 x 2.
    Media Time = 0ms.
    Stream Time = 0 ms.
    Filter : Digisuite DTVDVVideo Renderer1.
    Description :105C :A starvation event detected.
    Might it be my virtual memory? it’s set at 1536 MB, and i am not sure of repercussions if i change this.
    Peter Mcauley replied 19 years, 8 months ago 2 Members · 1 Reply
  • Peter Mcauley
    January 23, 2007 at 6:46 pm
    I’m wondering if you have the right forum as I didn’t see any mention of Boris in the post. You might want to post this to the Adobe list to see if someone there may be able to help.
    Cheers,
    Peter.
