Activity Forums Adobe Premiere Pro Premiere CS6 Preview Link Breaking
  • Premiere CS6 Preview Link Breaking
    Posted by Chris Deroche on January 14, 2013 at 7:32 pm
    I am in a facility that has about 20 Mac machines on a network. We all work off files located on a SAN. I am experiencing a problem with getting preview files to stay linked when the project is open on a different machine.
    I ran a bunch of tests with a rendered section on my own machine. I rendered a section, saved, closed reopened on the same machine. Renders were fine. I then changed the location of the project file several times, and the renders were STILL fine, so the project path didn’t make a difference (by the way, the scratch disk location is set to a folder on our SAN, NOT the default “Same as project”).
    Then I ran tests by rendering a section, saving and reopening that project on a different machine, and the renders disappear. Red bars all accross. Has anyone else experienced this? I tried combinations of checking and unchecking the Media cache box, as well as pointing that path to a location on the SAN instead of a local user application support folder, still no luck. Without a distributed processing option, we need to be able to render, say, overnight so the exports don’t take forever.
    Also, I have double checked to make sure the preview files are in fact there, and they haven’t moved. I can play them in qt or quick look)
    Thoughts?
    Most of our machines are of the following configs
    Mac OS X 10.6.8
    Premiere Pro 6.0.2
    Codec: ProRes LT 720 59.94
    16GB RAM 1066 Mhz
    Quad-Core 2.4 Ghz 2008 models
    GeForce 8800 512MB (a couple boxes have Quadro 4000s 2GB, ran the tests across both configs…same problem across those options)
    Chris Deroche replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
