Activity Forums Adobe Premiere Pro premiere cs6 playing on video hardware
  • premiere cs6 playing on video hardware
    Posted by Ian Kane on January 2, 2013 at 7:46 pm
    I am having an issue printing to tape with Premiere CS6. When I select Export > Tape, I receive a blinking message in the preview window, “Playing on video hardware.”
    I am using:
    OSX 10.6.8
    Blackmagic DeckLink SDI with Blackmagic Design Desktop Video 9.6.8
    Sony DVCAM DSR-2000
    My capture settings are set to Blackmagic Capture. Editing mode has been set to both Blackmagic Uncompressed and Quicktime DV NTSC (My video is 720×486 uncompressed 10 bit 29.97 fps), both yielded same results. Sequence settings have been set to both Blackmagic Design NTSC 4X3 and DV-NTSC, both yielded same results. Device Control is set to Blackmagic Device Control. My Sony DVCAM is in remote mode. All is hooked up correct because Final Cut Pro 7 prints to tape just fine.
    Anyone have any ideas?
    Tom Daigon replied 13 years, 8 months ago 3 Members · 2 Replies
  • Dan Packman
    January 9, 2013 at 4:36 pm
    I am having the same issue as well.
    I am doing some testing for laying off from Premiere CS6 using a Blackmagic card. I was able to output an SD sequence to D-Beta with some glitches but when I go to HD, I get the flashing blue “playing on video hardware” I’ve exported out a self contained QT of the file and brought it back in to see if that helps, but it yielded the same results. Any help would be most appreciated! Thanks!
  • Tom Daigon
    January 9, 2013 at 4:48 pm
    Send Adobe a bug report so they can fix it 😀
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
