Premiere CS6 Markers change source file modification date?
I’ve discovered that if you add Markers to a source clip in Premiere CS6, that it changes the modification date of the source file. I’ve also found that the markers are saved somehow as a part of that source file. If that clip is brought into another, new project, the markers are there with the clip.
This is seemingly harmless, but this new metadata is actually confusing CatDV (sorry to throw in another application) into thinking the file is a new file, so I’m thinking that this is something I should pay attention to.
When I use a “non-destructive” NLE, I don’t want it making any changes to my source material. And on a workflow note, I don’t particularly want markers from one project to be carried across to another project.
Does anyone have any experience with this? Is this supposed to happening or is this some kind of bug?
Thanks for any help.
Gerald Goldman
Director of Post Production
Grace Creek Media
http://www.gracecreek.com
http://www.sportskool.com
