Activity Forums Adobe Premiere Pro Premiere CS6- how to monitor via BM Ultrastudio express?
  • Premiere CS6- how to monitor via BM Ultrastudio express?
    Posted by Larry Wheeler on February 8, 2013 at 2:00 am
    Forgive me. I am totally new on Premiere. How do you get Premiere to see your I/O, for monitoring, or capture? This is easy in AE, but nowhere to be found in Premiere. Help would be very much appreciated!
    Larry Wheeler replied 13 years, 7 months ago 4 Members · 9 Replies
  • 9 Replies
  • Alex Gerulaitis
    February 8, 2013 at 5:49 am
    I believe it’s Menu – Edit – Preferences – Playback – Video Devices. If you have the drivers installed, there should be a “Blackmagic Device” or something like that.
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
  • Larry Wheeler
    February 8, 2013 at 2:08 pm
    I thought so too, however, when I pull this up, no options for the UltraStudio show up. This is the same on the MacPro with a KONA3 in it as well. That machine interacts with KONA3 via AE CS6, yet Premiere doesn’t see it. On the MacBook Pro Retina, I have BlackMagic Desktop Video 9.6.9 installed, and with other programs it works great. Just cant get Premiere to see it.
  • Alex Gerulaitis
    February 8, 2013 at 4:55 pm
    Was Pr installed later than AE, or re-installed, or had its preferences trashed? Tried re-installing the drivers?
  • Gary Milligan
    February 8, 2013 at 6:02 pm
    Sorry I can’t help you Larry, but I’m having the same issue with my AJA Kona HLe – CS6 AE sees it, PP audio sees it, but PP video playback doesn’t work. Any suggestions for me?
    I’m on a Mac Pro, 10.6.8, 2 x 3 GHz Quad-Core Intel Xeon, 16GB RAM, NVIDIA GeForce 7300 GT
    Thanks.
  • Kris Merkel
    February 8, 2013 at 6:05 pm
    Hi Larry, Just saw your post on twitter. For the Kona card you will have to install the AJA MAC plug in for PrPro and as far as the UStudio goes. The option should be there. As a test you can set a sequence to one of the BMD settings, import your video and see if it recognizes the output card. Which UltraStudio are you using? SDI?
    I have an IOXT and a US3D that I use here with no problems
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Larry Wheeler
    February 8, 2013 at 6:36 pm
    Thank YOU! I have the UltraStudio Express, it’s the SDI with Thunderbolt. I will try the sequence test! The AJA plugin for Premiere, that’s good info! Thank you for the help!!!
  • Larry Wheeler
    February 8, 2013 at 6:38 pm
    Premiere was upgraded from 5.5 at the same time on the MacPro, and the CS6 install on the laptop was all new, at the same time.
  • Larry Wheeler
    February 8, 2013 at 6:53 pm
    Might try this, worked for my Kona3 on CS6
    https://www.aja.com/en/support/downloads/
  • Larry Wheeler
    February 9, 2013 at 1:00 am
    Kris, This worked wonderfully! I created a new project, and chose a BlackMagic Design format, and there it was. Working great! Thank YOU!!!!
