Activity Forums Adobe Premiere Pro Premiere CS6 export not working
  • Premiere CS6 export not working
    Posted by Allby Corry on October 26, 2012 at 12:42 pm
    Hello,
    I have a new problem with Premiere CS6.0.3, in Win7.
    Sometimes the Export Media does not work, especially with older projects.
    To export a sequence I need to open the Media Encoder.
    But when I try to import a Premiere Sequence popup a series of warnings:
    “The drive is not ready for use; its door may be open. Please check drive A: and make sure
    that a disk is inserted and that the drive door is close”.
    If I click cancel a new windows open:
    “There is no disk in drive. Please insert a disk into drive DeviceHardisk4DR4.”
    “There is no disk in drive. Please insert a disk into drive DeviceHardisk4DR5.”
    “There is no disk in drive. Please insert a disk into drive DeviceHardisk4DR6.”
    After canceling then again I use.
    Does anyone have any idea what is happening?
    Thanks in advance.
    Allby Corry replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
