Activity Forums Adobe Premiere Pro Premiere CS6: Can You Apply Effects To A Clip From The Project Panel
  • Premiere CS6: Can You Apply Effects To A Clip From The Project Panel
    Posted by Chris Martin on March 8, 2013 at 8:03 pm
    Neophyte Premiere CS6 question – can you apply an effect, example Warp Stabilizer, directly to a clip independent from the timeline or must it first be in the timeline?
    Cheers, Chris
    Jeff Pulera replied 13 years, 6 months ago 2 Members · 1 Reply
  • Jeff Pulera
    March 8, 2013 at 8:38 pm
    Hi Chris,
    A clip must be in a Sequence before you can add effects to it. Once on the timeline, 3 ways to add an effect –
    1) drag effect onto clip
    2) select clip and drag effect to Effect panel
    3) select clip then double-click effect, is added to Effects (PC)
    Jeff Pulera
    Safe Harbor Computers
