Activity Forums Adobe Premiere Pro Premiere CS6 and Decklink HD – HDV
  • Premiere CS6 and Decklink HD – HDV
    Posted by Allby Corry on February 25, 2013 at 10:44 am
    How can I create a HDV 1440×1080 HD Anamorphic sequence and get image on output monitor
    via HDMI with Decklink Extreme HD?
    I have already set up the Decklink as the monitoring output and is working with the sequences NTSC and HD (BlackMagic only).
    The problem is that there is no sequence in BM-1440×1080 HDV in CS6.
    I’ve edited a sequence to 1920×1080, changing to 1440×1080 , but does not work no image on monitor output.
    If I drag a file to the timeline to create a sequence that is not BM, for example a 1440×1080 M2T file, does not work, the signal is not shown in the monitor program.
    Thanks in advance.
    Allby Corry replied 13 years, 6 months ago 2 Members · 3 Replies
  • Richard Knight
    February 26, 2013 at 10:27 am
    With Premiere CS6 the new ‘Transmit’ function should allow you to use any sequence with the BM card.
    Richard Knight
  • Allby Corry
    February 26, 2013 at 7:04 pm
    Thank you Richard,
    But something strange is happening.
    I can only see the image on the output monitor if I create a sequence BM.
    As I said if I drag a 1440×1080 image file to create a new sequence, it is not shown on the output monitor.
    Any idea what might be happening?
    Tx
  • Allby Corry
    February 28, 2013 at 7:05 pm
    Richard,
    I received an email from BM support and it is not any sequence that can be used with the BM card:
    Hello Alberto,
    Unfortunately, you will not be able to do this.1440×1080 is HDV (as you know). None of our products capture in HDV.
