Activity Forums Adobe After Effects Premiere CS5.5 + Twixtor – Big Problem!
  • Premiere CS5.5 + Twixtor – Big Problem!
    Posted by Piotr Abramowski on August 8, 2011 at 2:23 pm
    My problem is:
    Previously worked on the program: Premiere CS5 + Twixtor 5 – everything was OK!
    on the timeline – insert a full stop at 100% (speed), the second dot at 60%, and the third period to 100% – I received as a result of the effect: Normal speed – a sudden release and normal speed again …..
    Now, I bought Premiere CS5.5 + Twixtor 5 – There was a problem and I do not know what to blame.
    Now when I put a dot – 1,2,3 …. etc.
    I HAVE THIS PROBLEM – https://www.youtube.com/watch?v=rTH9HUMHPn4(does not release properly and does not render)
    Very please help and any tips,
    twixtor I use to work, to me it is very necessary!
    Please help,
    Robert.
    Pierre Jasmin replied 14 years, 10 months ago 3 Members · 21 Replies
  • 21 Replies
  • Piotr Abramowski
    August 8, 2011 at 3:01 pm
    Link Film Problem – “https://www.youtube.com/watch?v=rTH9HUMHPn4”
  • Pierre Jasmin
    August 8, 2011 at 6:38 pm
    I am not clear what your problem is watching the video, is it that you want to extend the clip duration?
    Seen these tutorials?:
    https://help.revisionfx.com/album/20/
    In case also if the frame rate is not the same as the project, you have to go to File|Modify|Interpret Footage and set “Assume this frame rate” ans set that to your project frame rate.
    Pierre
  • Piotr Abramowski
    August 8, 2011 at 10:06 pm
    My problem is very simple – just hard for me to explain it (I forms usa) …
    See you at this tutorial: https://help.revisionfx.com/album/20/ # / tutorial-75
    I want to do their own project, just something like that! – And unfortunately I can not!
    First of all – the image jumps when I change the value from 100% to 60%
    and secondly – I’m losing to render the file (like a movie)
    I ask if anyone has this problem who uses Premiere CS5.5?
    Let me add that I have the original version of Premiere CS5.5 and original Twixtor.
    Please help!
    Robert.
  • Pierre Jasmin
    August 8, 2011 at 10:15 pm
    You might need to work in “frame” mode in Twixtor like in the second part of this tutorial:
    https://help.revisionfx.com/album/20/#/tutorial-75
    I am not sure what this means “I’m losing to render the file (like a movie)”, not english. Do you mean the sequence is not long enough?
    If so watch the tutorials…
    Pierre
  • Piotr Abramowski
    August 9, 2011 at 6:05 am
    Sorry for my English (translate.google )….
    iframe it does not help!
    It’s not about the length of the film.
    Please watch my film to the end – See how the timeline gets red.
    That should not be!
    By this at all can not be used twixtor.
    I have no idea what to do next ….
  • Piotr Abramowski
    August 9, 2011 at 7:54 am
    I created a video specifically to show my problem exactly (cs5 premiere and premiere cs5.5). I tested the premiere cs5.5 of twixtor 5.0.2, 5.0.4 (even a trial version) – does not help. Are left for me to work on premiere cs5? Does anyone know the solution?
    LINK FILM – “https://www.youtube.com/watch?v=OZf_Fp50M0A”
  • Pierre Jasmin
    August 9, 2011 at 6:55 pm
    Piotr,
    I am having an hard time replicating your problem (works here). I presume what you say is you hit “Enter” – Render Effects in work area.
    Also check your keyframes are what you think they are, in CS5.5 I noticed the first keyframe is sticky and sometimes does not stay the proper value.
    Can you write to techsupport at revisionfx dot com for instructions on how to send a movie + project here?
    Pierre
  • Piotr Abramowski
    August 9, 2011 at 8:18 pm
    I’m sorry but I do not understand what to do.
    Yes, I hit “enter” to render effects in work area.
    All keyframes are good and have a good value.
    Are you suggested I sent a message to the techsupport in RE:vision?
  • Pierre Jasmin
    August 9, 2011 at 8:24 pm
    YES suggesting you write to us so we can get source movie and prproj file to replicate (it works for me here)
    Pierre
  • Piotr Abramowski
    August 9, 2011 at 8:38 pm
    OK – I’ll send source file and a project of the premiere cs5.5
    But I noticed that the first value in twixtor – value changes from 100% to 60% (all the time )…..
    Piotr.
Page 1 of 3
