Activity Forums Adobe Premiere Pro Premiere CS5.5 conforming
  • Premiere CS5.5 conforming
    Posted by Allby Corry on September 9, 2011 at 11:19 am
    I’m working on a project in Premiere CS5.5 with MTS files that were sent by the client.
    But every time I open the project or even during editing, Premiere begins to make conforming files, and it is almost impossible to work.
    A error occurs:
    “An unspecified error occurred while performing a conform action on the following file: drive/folder/namefile.MTS 4800.cda”
    Is there any way to stop this, or another way to import the MTS files?
    I’m using Premiere CS5.5 on a PC win7 64bits with Matrox MXO2 Mini.
    The files properties is:
    File Path: P:\filename.MTS
    Type: MainConcept AVC Import
    File Size: 1,3 GB
    Image Size: 1440 x 1080
    Frame Rate: 29,97
    Source Audio Format: 48000 Hz – 32 bit floating point – 6 channels
    Project Audio Format: 48000 Hz – 32 bit floating point – 6 channels
    Total Duration: 00:34:19:00
    Average Data Rate: 673 KB / second
    Pixel Aspect Ratio: 1,3333
    Video: H264/AVC – top field first – 16.000 Mbit/sec
    Audio: Dolby Digital – 48000 Hz – 32 Bit – 6 Channels
    Thanks in advance.
    Allby.
    Lyn Norstad replied 14 years, 11 months ago 2 Members · 3 Replies
  • Lyn Norstad
    September 9, 2011 at 7:44 pm
    Allby –
    Premiere does not like CDA (CD Audio) files. I suggest you take them into Audition and convert them to WAV files.
    Regards,
    Lyn Norstad
    Chicagoland, USA
    Co-host of CreativeCOW forums:
    Matrox Video Systems
    Stardom storage
    Leitch dpsVelocity
  • Allby Corry
    September 9, 2011 at 9:53 pm
    Thank you, Lyn,
    Is possible I take the clips into Audition convert to WAV and have this new audio attached with video?
    Regards,
    Allby
  • Lyn Norstad
    September 13, 2011 at 3:07 pm
    You’ll have to link them manually in Premiere, Alby. Just like you would with the CD Audio files.
    Regards,
    Lyn Norstad
    Chicagoland, USA
    Stardom storage
    Leitch dpsVelocity
