Activity Forums Adobe Premiere Pro Premiere CS5.5 Audio tidy-up: gain plus Dynamics?
  • Premiere CS5.5 Audio tidy-up: gain plus Dynamics?
    Posted by Lucy Moon on July 9, 2013 at 10:10 am
    Hi All.
    I’ve been boosting interview audio with first a gain setting to adjust overall peaks, then adding Dynamics to compress and limit it.
    I wondered – since the Dynamics has the “MakeUp” adjustment, if that’s just gain, so am I duplicating gain where I should perhaps do it all in the Dynamics filter?
    Any thoughts?
    ~Astrid
    MacBookPro 2.2 GHz intel core duo/ 6 GB RAM / GeForce 8600M GT
    Mac Pro 2.8 Quad / Nvidia Quadro 4000 / 12 GB RAM / OSX 10.7
    Hackintosh 3.41 i7 / AMD Radeon HD 6870 /16 GB 1 / OSX 10.7
    Angelo Lorenzo replied 13 years, 2 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    July 10, 2013 at 4:48 pm
    There are multiple “gain stages” or points in the signal path where you can add gain to audio within Premiere.
    Taken simply, consider the following:
    Clip-based effects and clip volume adjustments
    Gain applied in effects in the track mixer
    The track level slider
    I would suggest leveling your voice clips in the timeline to a consistent level that way they all hit the compressor you get the same result. Adjust the makeup gain so you have a solid working level.
    I would leave the track slider, if possible, to control the volume of the track for final mixing against other tracks rather than getting it to a “workable” level as another gain stage.
    tl;dr use make-up to set a workable level, use the audio mixer to mix against other tracks. Not really a quality issue so much as it sets things up for easier manipulation.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
