Activity › Forums › Adobe Premiere Pro › Premiere CS5.5 Apply a constant power top and tail to all clips?
  • Premiere CS5.5 Apply a constant power top and tail to all clips?
    Posted by Lucy Moon on June 26, 2013 at 11:51 am
    Hiya,
    PP newbie here. I have interview sound bites separated by black video clips (ie. clips aren’t bumped up to anything) and I’d like all my audio to have some “softening” at the beginning and end.
    The constant power effect (3 frames or so) works, but I can’t see how to add this en-masse.
    Any ideas?
    Astrid
    MacBookPro 2.2 GHz intel core duo/ 6 GB RAM / GeForce 8600M GT
    Mac Pro 2.8 Quad / Nvidia Quadro 4000 / 12 GB RAM / OSX 10.7
    Hackintosh 3.41 i7 / AMD Radeon HD 6870 /16 GB 1 / OSX 10.7
    Ann Bens replied 13 years, 3 months ago 2 Members · 1 Reply
  • Ann Bens
    June 26, 2013 at 8:42 pm
    If they were butted you could have used Apply default transition to selection.
    But as they are not you will have to select every edit point.
    Fastest way is to use shortcuts: Ctrl+D for adding default transition and Arrow up to go to the next editpoint.
    Set Constant Power to default transition and also set duration in the Preferences
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
