Activity Forums Adobe Premiere Pro Premiere CS5 uses 97% RAM when conforming audio
  • Premiere CS5 uses 97% RAM when conforming audio
    Posted by Andy Milne on May 17, 2011 at 2:42 am
    I am having trouble with using an XDCAM clip in Premiere CS5. When I access the clip Premiere starts conforming the audio but it slowed the maxhine right down to a crawl. I have 6GB RAM and have set the RAM usage in Premiere to 4GB leaving 2GB for the system. But on first acces to the XDCAM clip Premiere starts conformaing and the RAM usage ramps up over 10 seconds. It does not limit to 4GB and maxes out at 97% total RAM usage so the system grinds to a halt.
    Anyone having similar trouble?
    Cheers
    Andy
    Andy Milne replied 15 years, 2 months ago 3 Members · 4 Replies
  • Jeff Greenberg
    May 18, 2011 at 4:04 pm
    I’m not – but could you give us the major details of your machine:
    CPU(s), motherboard, drive connection & speed…
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Andy Milne
    May 18, 2011 at 11:06 pm
    Hi Jeff. Thanks for the reply. System is as follows:
    Core 2 Quad Q8400
    Asus P5Q SE2
    6GB Ram
    RAID 0 2x2TB WD Green
    Premiere 5.0.0
    Cheers
    Andy
  • Russell Shaver
    June 30, 2011 at 3:58 am
    Yeah, I have the same problem. Anytime I import large folders the conforming takes for ever and slows system down to a crawl. Keep getting low memory warnings. Actually had the same problems with CS3. I think I’m about done with Adobe. So much money and time, and the pos program is still mostly unusable. Who are these idiots that are always claiming the Premiere is rock solid now? Amazing.
  • Andy Milne
    June 30, 2011 at 9:34 pm
    I did find a solution in upgrading to CS5.5 which fixed the problem. It is possible 5.0 updates might fix it too but didn’t try that.
    I can confirm that with 5.5 conforming audio is quick and does not max out the memory.
    Cheers
    Andy
