Activity › Forums › Adobe Premiere Pro › Premiere CS5 preview problem
  • Premiere CS5 preview problem
    Posted by Dasca Thea on August 3, 2010 at 3:02 am
    HI everybody. i have been googling abt my problrm, and it seem that no one is experiencing this.
    When i have file in my timeline rendered, it preview crap.
    this is my print screen:
    this happens to every footage i import.This is PAL 720*576, progressive 25fps, aspect of 1.09 sequence.
    although it preview like this, the exported file is fine.
    My sys config is:Win 7 64bit, Q6600@2.4Ghz 4Gb ram and
    ATI radeon HD 4870
    i know that mercury dont support ATI. is this being the problem? anyway i can disable mercury? i dont need it anyway if this is the problem. CS5 is more peacful to work with than CS4.
    Dasca Thea replied 16 years, 1 month ago 3 Members · 6 Replies
  • Angelo Lorenzo
    August 3, 2010 at 4:21 am
    It looks like the rendering process is mixing up or shifting YUV values.
    What codec/container is the original footage in?
  • Mike Velte
    August 3, 2010 at 9:57 am
    Try updating video card drivers, if that fails turn down hardware acceleration for the video card.
  • Dasca Thea
    August 3, 2010 at 4:02 pm
    hi,
    i think the video codec is Microsoft avi or Dv Pal.. i dont know. but this clip would work juz fine in CS4!!
    i cant figure out why.
  • Dasca Thea
    August 3, 2010 at 4:11 pm
    hi,
    I think i already have the latest driver. ATI HD 4870 under driver version 8.741.
    Where can i turn down hardware acc. for the card? if u are talking abt the option in playback setting. i did that, and it didnt help.
    i also think turning that down would do the trick, but i dont know where.
  • Mike Velte
    August 3, 2010 at 6:19 pm
    Hardware acceleration is:
    Control Panel>Display>Screen Resolution>Advanced Settings>Troubleshoot>Change Settings
    If you have to turn it down very far to fix the problem, your video card may not be working correctly.
  • Dasca Thea
    August 4, 2010 at 6:06 am
    OH MY GOD, it works…:D thank you so much…
