Activity Forums Adobe Premiere Pro Premiere CS5 and Kona LHi problem
  • Premiere CS5 and Kona LHi problem
    Posted by Brian Smith on February 16, 2024 at 6:03 pm
    Hi, after getting a new Solid state hard drive and reinstalling Premiere CS5, I’m trying to instal the drivers and plugins for AJA Kona LHI and Premiere just wont see the AJA stuff like in sequence settings there isn’t any AJA options or when I start a new project, I can’t make an AJA timeline ect..I’m think I downloaded the wrong drivers or I’m missing a step. I tried AJA drivers 5.5.2 and 10.0 so far. Any thoughts?
    Brian Smith replied 2 years, 7 months ago 2 Members · 2 Replies
  • Hector Vera
    February 19, 2024 at 4:52 pm
    It could be the wrong drivers that you have installed. Did you restarted your computer after installing the plugin and then reopening Premiere Pro to see if this plugin is properly installed?
    Make sure you download the plugin from the official website of AJA here and be sure its EXACTLY compatible with your version of Adobe Premiere Pro: https://www.aja.com/support
    Hope it helps and best of luck!
  • Brian Smith
    February 23, 2024 at 3:21 pm
    Hey, thank you for your reply, in the end I had installed the wrong drivers and finally found the correct one like 5.0.2 or something. So far everything is working. Again thanks
