Activity Forums Adobe Premiere Pro Premiere CS4 rendering problems
  • Premiere CS4 rendering problems
    Posted by Scardellato Egidio on June 11, 2009 at 3:21 pm
    I’m mounting a non professional film (about one and a half hours with 4 sequences) with Vista 64 b., Adobe Creative suite 4, AVCHD 1080i 25, on a dual quad core Xeon E 5430 and DDR 2 667 Hz 4×2 Gb.
    No problem with mounting and rendering the first hour but then, with no apparent reason, i coul go on with transitions and effects, but the program broke every time I tried to render the mounted clips.
    Is there any hidden command to solve the problem?
    Should I ignore the rendering will the transcoding work?
    Thanks to everybody which might help
    Sean Aquilina replied 16 years, 7 months ago 3 Members · 6 Replies
  • Eddie Lotter
    June 11, 2009 at 4:19 pm
    You need to apply the latest updates to CS4.
    Cheers
    Eddie
  • Scardellato Egidio
    June 12, 2009 at 6:11 pm
    Update done a week ago – I’ll do it again hoping to solve the problem – thanks for your suggestion
    EgiscA
    egisca
  • Eddie Lotter
    June 12, 2009 at 8:56 pm
    Then try these troubleshooting tips.
    Cheers
    Eddie
    June 15, 2009 at 8:54 am
    dear Eddie
    Just to keep you posted
    Updated again Premiere and tried some of the tips you suggested: nothing doing
    Finally I verified the file system (which actually doesn’t work wery well);
    -too many Program versions were saved
    -the same prevew and rendering folders and files were repeated up to five times, at various levels, and the System was unhable to mantain control on rendering.
    So I deleted all those prevew and rendering folders and files and copied in one Progect version all the related files of the other versions and then cancelled them.
    Now (I say it in a low voice)the problem seems to be solved
    Thanks for your help
    egisca
  • Sean Aquilina
    January 21, 2010 at 4:05 pm
    Hi
    I’m having a problem with rendering in Adobe Premiere CS 4.0
    The image AND text/cg seem to be sharp without rendering (with the red bar)
    but if exporting without rendering, the image will loosen, sharpness is almost lost competely.
    The problem is that, when I render, on the monitor of premiere project it self, you can easly see pixilated results. (both for text and image, sharpness is lost totally) tried to export but same problem.
    I’ve read some forums about this problem
    and I tried to change optimize to MEMORY (from performance) but nothing changes.
    I made sure that the formats and codecs are the same, and the files I’m using arent duplicated. I even formatted my system, using OS XP and Windows7 seperately, nothing changes, always the same problem.
    I’m working with
    DV-PAL 4:3 interlaced
    25:00 fps
    Frame size: 720h 576v (1.0940)
    Frame rate: 25.00 frames/second
    Pixel Aspect Ratio: D1/DV PAL (1.0940)
    Fields: Lower Field First
    Audio Settings
    Sample rate: 48000 samples/second
    I tried to change the field to lower/upper and even progresive but continouly the problem was the same through out.
    Something I wish to add, when I move slightly the picture and it has sharp edges, after rendering, the sharpness is again lost completely.
    Is there any solution for my problem please?
    This problem happened in all of a sudden, I used to work out fine until once this problem occured wuthout adjusting any settings.
    Can someone help me please??
  • Sean Aquilina
    January 21, 2010 at 9:48 pm
    Hi
    I’m working with
    25:00 fps
    Audio Settings
