Activity Forums Adobe Premiere Pro Premiere CS4 R3D’s and Blackmagic Card
  • Premiere CS4 R3D’s and Blackmagic Card
    Posted by Thad Ciechanowski on September 14, 2010 at 12:31 pm
    I’m about to edit a project shot on the RED using CS4 with the 1.7 Plugin. I have a Blackmagic Intensity card hooked up but I can’t get any output from the card unless it’s a Black Magic sequence. Is that just the nature of that particular BM card or is that just BM/Premiere. I can’t seem to find any documentation that indicates whether a card will work with the R3D presets or not. Does the Decklink do the same thing? Don’t want to buy another card unless I know for sure.
    At the moment, I’m using Windows XP 32bit since Windows 7 won’t work with my graphics card.
    HPxw8400
    2X 2.66Ghz Dual Core Xeon
    NVidia FX1300
    4GB RAM
    Windows XP SP3
    Premiere Pro 4.1
    http://www.dijitmedia.com
    Panos Ioannou replied 15 years, 11 months ago 3 Members · 3 Replies
  • Vince Becquiot
    September 14, 2010 at 11:44 pm
    Yes, most cards, including those from BM / AJA will require that you set up a project that makes use of the drivers for that particular card.
    As an alternative, you could simply use a dual head DVI Nvidia card, or 2 cards and tell Premiere to output full screen on the second display.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Thad Ciechanowski
    October 4, 2010 at 5:10 pm
    Thanks Vince,
    So I’m able to use 2 NVidia Cards? I want a 3 monitor setup with the third as a client monitor.
  • Panos Ioannou
    October 4, 2010 at 8:44 pm
    Hi
    I cant find a codec that works for red footage for the following specs….
    CS4
    Windows 7
    NVIDIA Quatro FX 5600
    D10 lenova
    Dual Quad Xeon 3.0GHZ
    16GB RAM
    We are not upgrading anytime soon to CS5 so trying to find a solution.
    Hope someone can help
    Cheers
    Panos
