Activity › Forums › Adobe Premiere Pro › Premiere CS4 FireWire playback issue
  • Premiere CS4 FireWire playback issue
    Posted by Pedro Lourenço on April 9, 2009 at 3:19 pm
    Premiere Pro CS4 has different ways to setup playback settings from CS3.
    I can’t preview in firewire, also I can’t export to tape, record to tape and nothing.
    The wierd thing is: I can capture using firewire, but I can’t make the video signal on external device.
    Important: I use an iMac and EVERYTHING goes fine with Final Cut Pro 5.
    So it’s NOT a matter of cabe, FW card, Mac OS settings, external device setup, and so on.
    It’s somenthing in this new CS4 settings that I can’t figure out how to preview on external device.
    (I also have this problem on Windows, I’m hating CS4 version of Premiere)
    Any help?
    !iPedroMac!
    Pete Smoyer replied 15 years, 7 months ago 4 Members · 3 Replies
  • Eddie Lotter
    April 9, 2009 at 5:23 pm
    Did you follow these instructions in the Premiere Pro Help?
    Cheers
    Eddie
  • Fernando Mol
    May 9, 2009 at 6:05 pm
    In the Program Monitor (or source monitor) open the output menu (the tree rgb circles) then select “playback settings”.
    A window will open. There you can select your external device.
  • Pete Smoyer
    February 27, 2011 at 3:38 pm
    After struggling with this problem for hours FINALLY a clear solution. Thank you!
