Activity Forums Adobe Premiere Pro Premiere CS4 File Management Question
  • Premiere CS4 File Management Question
    Posted by Douglas Heck on May 4, 2010 at 11:31 am
    The Case: Editing a sports video for a school and have set up a Premiere project for each sport separately. There are many clips (and subclips) in each of these projects that I would also like to use in a closing segment….which is also a separate Premiere project.
    Question: What is the easiest way to select a clip that has been imported into one Premiere project and “send it” to another Premiere project? Or do I have to write down the name of each clip and its respective location and manually import it into the “Closing Segment’s” project?
    Any help is appreciated.
    FWIW: Footage is 1080p, M2T files. Using PPro CS4, Windows 7 Ult 64.
    Brian Barkley replied 16 years, 4 months ago 3 Members · 2 Replies
  • Eric Jurgenson
    May 4, 2010 at 2:07 pm
    Import one project into the other.
  • Brian Barkley
    May 4, 2010 at 4:04 pm
    In premiere pro, select the Media Browser Panel and find the file and then import it to the Project Panel.
