Activity Forums Adobe Premiere Pro Premiere CS4 Audio timeline
  • Premiere CS4 Audio timeline
    Posted by Del Taylor on September 10, 2009 at 6:13 pm
    Has anyone else noticed that the audio timeline sometimes does not accept audio tracks?
    Example: i pull a wav file from the library and try to add it to audio track line #1 but Premiere forces me to add the track to line #3. It actually prevents me from adding audio tracks WHERE I want them at times.. is there a reason for this??
    Richard Baim replied 17 years ago 2 Members · 1 Reply
  • Richard Baim
    September 10, 2009 at 8:00 pm
    Is the audio in the WAV file something other than stereo? If it’s mono or 5.1, and you try to drag it onto an existing stereo track, Premiere will create a new track to match the number of tracks in the file. In other words, you can’t drag a mono or 5.1 file onto a stereo track.
    If the track you want to work with is 3, you can always delete 1 and 2. Additional tracks can be added later if needed.
    Rich Baim
