Activity Forums Adobe Premiere Pro Premiere CS4 adjust render preview
  • Premiere CS4 adjust render preview
    Posted by Patrick Pulito on February 22, 2010 at 1:16 am
    Hi
    how can i ajust the rendering of the right preview window in adobe premiere so that it wont be rendering the fulle video? I mean, can i adjust the premiere so that a long video can be rendered for the preview at a manual time? For example by hitting the “Enter” tast and it begins to render at 32:00. Not from 00:00.
    Because this takes a lot of time when it renders – only for the preview ! – at the beginning of the video…
    Thanks a lot
    greetz from germany
    Patrick Pulito replied 16 years, 7 months ago 2 Members · 4 Replies
  • Jon Barrie
    February 22, 2010 at 3:58 am
    Set the Work Area Start and End to the desired area and rendering will only occur in that section.
    Drag it with the mouse or use Alt+[ for snap start to CTI (playhead) position and Alt+] for snap end to CTI position.
    – Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Patrick Pulito
    February 22, 2010 at 6:58 pm
    can you show me pls which tool it is on this picture? https://www.file-extensions.org/imgs/app-picture/2082/adobe-premiere-pro.jpg
  • Jon Barrie
    February 22, 2010 at 10:51 pm
    I’ve taken the screen grab provided and highlighted the area that is the work area bar. Then circled the ends to indicate the “hooks” that are the work area bar start and end points.
    You can either grab the hooks and drag them where you want them (they will snap to cuts with snapping function. Or you can position your playhead (CTI – current time indicator) and use the shortcuts alt+[ for start and alt+] for end.
    Good Luck.
    – Jon Barrie 😉
    Jon Barrie
    aJBprods
  • Patrick Pulito
    February 23, 2010 at 9:34 am
    thx a lot 🙂 it works 🙂
