Activity › Forums › Adobe Premiere Pro › Premiere CS3 project setting for 60P video file ?
  • Premiere CS3 project setting for 60P video file ?
    Posted by Reko Tomo on September 7, 2014 at 4:54 pm
    Dear users,
    I have a video file with the info like this
    Video
    Menu ID : 1 (0x1)
    Format : MPEG Video
    Commercial name : HDV 1080p
    Format version : Version 2
    Format profile : Main@High 1440
    Format settings, BVOP : No
    Format settings, Matrix : Default
    Format settings, GOP : N=1
    Codec ID : 2
    Duration : 25s 920ms
    Bit rate mode : Variable
    Bit rate : 26.3 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 60.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.339
    Stream size : 81.4 MiB (95%)
    What is the appropriate CS3 project setting to use ?
    A. HDV 1080i30 (60i) ? or
    B. HDV 1080p30 ?
    For the export format I still don’t know which one that won’t cause quality problem :
    A. Mpeg2 1440x1080i 29.97 ? or
    B. Mpeg2 HDTV 1080p 29.97 ?
    I don’t even know what is the quality difference between those two export format.
    Any kind of respond would be greatly appreciated.
    Thank you in advanced, and I’m sorry for my broken English.
    regards.
    Reko Tomo replied 12 years ago 2 Members · 4 Replies
  • Ann Bens
    September 7, 2014 at 10:31 pm
    Your file is 30p not 60p. Its 60 x 1/2 fields which make up to 30 fps.
    For project settings choose B. HDV 1080p30.
    You may need to interprete the footage to progressive.
    Premiere will probably interprete it as interlaced, but I am not sure.
    Export settings all depend on what the end product is going to be.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Reko Tomo
    September 8, 2014 at 3:59 am
    Hi Ann… many thanks for your respond.
    Today I shot a new sample from Sony Nex-7.
    original AVCHD file from camcorder shot in 50p mode info :
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=1, N=12
    Codec ID : 27
    Duration : 9s 580ms
    Bit rate : 25.6 Mbps
    Maximum bit rate : 26.0 Mbps
    Width : 1 920 pixels
    Frame rate : 50.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.247
    Stream size : 29.2 MiB (95%)
    Using ffmpeg, convert to mpeg2 with command line :
    for %%a in ("*.mts") do ffmpeg -i %%a -vcodec mpeg2video -qscale 3 -qmin 1 -intra -an -f mpegts %%~na.mpg
    resulting mpeg2 file :
    Video
    Menu ID : 1 (0x1)
    Format : MPEG Video
    Codec ID : 2
    Duration : 9s 580ms
    Bit rate : 35.0 Mbps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.338
    Stream size : 40.0 MiB (95%)
    Put the converted file to CS 3 HDV 1080p25 project setting.
    File properties from CS3 project window :
    Type: MPEG Movie
    File Size: 42.1 MB
    Image Size: 1920 x 1080
    Pixel Depth: 1920
    Frame Rate: 50.00
    Total Duration: 00:00:09:13
    Average Data Rate: 4.4 MB / second
    Pixel Aspect Ratio: 1.0
    A. Put the footage into the timeline (it show red thin line).
    When playback in CS3 monitor, it plays choppy – duration is correct.
    B. So I interpret footage : “assume this frame rate 25 fps”
    Put the footage back into the timeline, now the duration is double.
    Playback still choppy (but slower) and thin red line still there 🙁
    Export to mpeg2 HDTV 1080p 25, then I change the fps to 50 in AME video setting.
    Either from step A or B, CS3 complain :
    “invalid combination of framesize/framerate/profile/level. Please recheck the settings and try again”.
    Export to mpeg2 HDTV 1080p 25, nothing change
    From point-A : Encoded file plays oke, correct duration and not choppy but Media Player shows 5 second duration when after it reach 5 sec, the movie still play the rest.
    From point-B : Encoded file plays slow, and Media Player still show wrong duration.
    I have my headache :).
    What did I do wrong, friend ?
    Btw, Ann wrote : You may need to interprete the footage to progressive
    I’m sorry as I don’t know how to do that in CS3.
    Thanks once again for your kind reply, Ann.
    regards.
  • Ann Bens
    September 8, 2014 at 3:37 pm
    Your first file is hdv the second one avchd.
    Two different things with two different workflows.
    So which one are you going to use?
  • Reko Tomo
    September 9, 2014 at 4:56 pm
    Hi Ann,
    I’m very sorry for the confusion.
    From my first post, the Media Info is a converted file using ffmpeg from AVCHD. In ffmpeg I reduce to 1440 – hoping to match the CS3 HDV 1080i30 (60i) project setting.
    Later I’ve found from the internet that HDV compliant is 50/60i not 50/60p.
    In my second post, i take a new shoot (with another camera) as I posted the Media Info of the AVCHD file. Then using ffmpeg I convert this AVCHD file to mpeg2 (not HDV) without reducing to 1440.
    My CS3 can not open AVCHD file, that’s why I need to convert it first to mpeg2 with ffmpeg.
    Before, I’m used to shot in 50/60i mode from my either camera. Then I convert this 50/60i AVCHD file using ffmpeg to HDV 1440×1080 25fps interlaced. CS3 accept this HDV file without thin red line in the timeline window after I drop this file into the HDV 1080i25 (25i) project setting timeline.
    My problem appear when I shot in 50/60p mode, because :
    1. I’m not so sure to what kind of mpeg2 should I convert in ffmpeg, stay progressive (50p) ? or interlace ?
    2. The question posted here is after I decided to convert as progressive mpeg2. Then left me a question :
    a. what is the appropriate CS3 project setting for this progressive mpeg2 file ?
    Ann told me to use HDV 1080p.
    What happen the rest, I’ve explained it in my second post.
    I’m sorry for causing you the trouble and confusing sentences of my English.
    Thank you for your kind respond.
    regards.
