Activity › Forums › Blackmagic Design › Premiere CS3 and decklink
Posted by Baz Leffler on April 17, 2007 at 4:58 amI downloaded and installed Adobe Premiere CS3 and then proceeded to copy/paste all the required files to allow the Decklink functionability. Seems it all works as per PPro 2. An hour later got onto my local Apple store and ordered FCP 6 upgrade. But that was not related to Premiere; just thought you should know I swing both ways nowdays!
Baz
Adrian Tecson replied 19 years, 4 months ago 3 Members · 5 Replies -
Luke Maslen
April 17, 2007 at 5:03 amHi Baz,
Thanks for letting us know and that’s good news as the DeckLink 6.1 for Mac OS X drivers don’t have any specific support for Premiere Pro for Mac OS X but they do seem to work well. Naturally we shall include specific driver support for Premiere Pro on Mac OS X once it has been released.
Regards,
Luke Maslen
Blackmagic Design -
Adrian Tecson
April 17, 2007 at 8:07 pmHi Baz,
Why not try installing bootcamp on your Macpro/Decklink Station and install WIndows XP? Wouldn’t it be cool to be able to boot up to either PremiereProCS3/Windows or MacOS/FCP on one machine? hehe
Adrian
Baz Leffler
April 18, 2007 at 12:22 amHey Adrian
Yes I think it would be nice but my mac is a powerPC not intel and I don’t think it would work. And besides, the mac is my only respite from Bill Gates and his buggy software; I go there when I have cussed too many times!
Baz -
Baz Leffler
April 18, 2007 at 4:14 amNow I can add that I am a little impressed with CS3 and a BMD SD project.
I created a sequence with 4 uncompressed 10 bit avi’s on top of each other using motion to create a quad split (each had a frame size of 50%).
The whole lot played real time without a hiccup. Then I added number 5 and centered it. That was too much and started studdering so obviously 4 was the max on my system.
So I copied and pasted the clips into a PPro 2 timeline (yes, both apps opened at the same time!) and the best I got was only 1 clip with the motion filter to play. So it seems the CS3 playback engine has been optimised.
I also created a 1 min 50 sec multilayer dual track motion key sequence that played in real time unrendered. That was…
1 layer base vision avi
1 layer fill vision A avi
1 layer fill vision A matte shape avi
1 layer fill vision B avi
1 layer fill vision B matte shape aviI then copied the whole sequence into PPro 2 and it didn’t stand a chance of playing realtime.
So as a final test for PPro 2 I rendered it and it took 3 mins 21 secs.
In CS3 it took 2 mins 57 secs.
It should be noted that I am not sure if the installation of CS3 affected PPro2’s performance in anyway.
System tested was…
Multibridge extreme
Tyan Thunder K8WE 2 x dual core 275 opteron
4G DDR
Quadro FX540 PCI Express
Areca RC1220 8 Port SATA Raid card driving 8 x 300g drives; -
Adrian Tecson
April 22, 2007 at 6:20 amThis is great news Baz. I’ll try the CS3 beta on our BMD stations on Monday and see if I come up with the same results.
