Activity Forums Adobe Premiere Pro Premiere Color Correction
  • Premiere Color Correction
    Posted by Kiangalaxy on December 31, 2006 at 3:56 am
    I would like to ask wat filter should i add to do the color correction,
    i find out the visual, the color of the footages i have is dull, althought the set should be look colorful…
    i tried color corrector, level to try to make the visual looks colorful but i cant do it, i am using Premiere Pro 1.5, is there any other suitable filter ? to make the color more sharp ?
    thanks
    Tim Kolb replied 19 years, 8 months ago 5 Members · 4 Replies
  • Vince Becquiot
    December 31, 2006 at 7:37 pm
    Where does the footage come from ? There are some issue that arise from RGB to YUV and the symptom is usually what you describe.
    Other than that, you can work with the “levels” effect, play with the gamma function as well (also part of levels).
    Vince
  • Blast1
    December 31, 2006 at 8:43 pm
    To add to what Vincent mentioned, You should always preview color adjustment and correction on a external video monitor to get a more accurate insight of whats going on.
  • Aanarav Sareen
    December 31, 2006 at 11:43 pm
    Please subscribe to the Premiere Pro podcast. One of the newer episodes deals with basic color correction. After you follow the tutorial, increase the “saturation” property of the Fast Color Corrector effect to get more vibrant tones.
    Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Tim Kolb
    January 3, 2007 at 1:47 pm
    [Aanarav Sareen] “increase the “saturation” property of the Fast Color Corrector effect to get more vibrant tones.”
    Well, that would help, but if the gamma curve is set too high (value number too low), as can be the case on a computer RGB monitor, saturation won’t fix the dynamic problem.
    You need to look at the footage on an external video monitor and use the waveform display available in PPro to really tell what’s going on.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
