Activity › Forums › Adobe Premiere Pro › Premiere codec problem! Help Me Please!
  • Premiere codec problem! Help Me Please!
    Posted by Ricardo Lagido on March 6, 2007 at 11:17 pm
    My problem is that premiere is constantly going down. Whenever I open my project file, 4 ffdshow (it’s a codec) icons apear in the down right part of the computer (near the clock). I supose that’s the cause of the problem, but I don’t know what to do.
    Please help me! I’m despered
    Thank you
    Vince Becquiot replied 19 years, 6 months ago 2 Members · 3 Replies
  • Vince Becquiot
    March 7, 2007 at 12:00 am
    The problem is that the file you are importing into Premiere is probably using this codec, but it might work without it.
    Just know that premiere really doesn’t support many of those external codecs. You can probably remove FFDshow from the Add / Remove Programs area, if not, go to: Control Panel > Switch to “Classic View”, then go to Sounds and Audio Devices > Hardware Double click on “video Codecs” > Properties tab and see if you can remove FFDShow from there.
    Vince
  • Ricardo Lagido
    March 9, 2007 at 10:07 pm
    ok, I’ve just uninstalled ffdshow, but now I can’t see the movies. What’s the best codec choice you recomend?
  • Vince Becquiot
    March 11, 2007 at 2:58 am
    Since FFDShow is comprised of many codecs, you will need to know the codec that was used to compress the particular footage you are using. If it’s DivX, then you need the Divx Codec. What I would do is download a copy of GSpot, a tiny free application: https://www.headbands.com/gspot/v26x/index.htm
    After install, start it up and drag the footage file to the window. In the top right it will tell you what codec was used, it will just be a matter of downloading it.
    Of course, it could also be that Premiere just doesn’t like that particular codec…
    Vince
