Activity Forums Adobe Premiere Pro Premiere CC2014.1 freeze at 120 fps from Gopro Hero 4
  • Premiere CC2014.1 freeze at 120 fps from Gopro Hero 4
    Posted by Arve Hansen on December 9, 2014 at 6:35 pm
    I have used the old Version Premire CC. and have no problem.
    Yesterday I installet 2014.1.
    I can put Canon 5DmkIII footage, Sony A6000 and Gopro Hero 4 Black 1920×1080 25fps (PAL) into the timeline, and scroll forward and backward, and play without any problem.
    But when I drag in a Gopro 4 1920×1080 120fps. Still now problem playing the first Clip from Sony A6000, but when it coms to the 120fps it slows Down speed and freeze after 2-5 sek. Freeze for a while and go slow for 2 sec and freeze.
    The task manager has 8 CPU’s columns. The first columns og right to the to. 7 above is more normal.
    I can then drag the marker back to the other Clips in 25fps and now problem at all there.
    Also tried wihtout CUDA and only software. Still the same.
    Using GTX 770 grafic card. Update the driver to 344,75. Noting helpet.
    Use Win 7 64, 12GB memmory, Intel I7-920 and 2X Seagate 3TB(7200rpm) in raid0.
    The same 120fps was now problem in the old Premiere CC.
    Gopro Hero 4 Black
    Arve Hansen replied 11 years, 8 months ago 1 Member · 1 Reply
