Activity › Forums › Adobe Premiere Pro › Premiere CC, RED EPIC Workflow
  • Premiere CC, RED EPIC Workflow
    Posted by Lukas Dreser on March 7, 2014 at 4:30 pm
    Hello there,
    I am gearing up to be cutting a short shot on the Epic. I believe either 5k or 4k.
    Before I make mistakes, I wanted to smooth some things out as far as the workflow goes for this project.
    I will be working on a fairly powerful PC (no red rocket card), and I am aware of being able to cut natively now inside Premiere Pro CC.
    Some questions I had though,
    1.
    When I setup my sequence, do I set it to the native resolution of the raw files (4k) and cut with lower res playback setting ? Or do I setup a 1080p seq. and drop the 4k files into it, and then scale to frame size ? Is there any advantage of doing it one way or the other ?
    2.
    When I need to push in on certain shots and possibly reframe, is it just a matter of zooming in on the footage ?
    3.
    Most likely we will be outputting to 1080 with the possibility of some festival submissions in the future, which would probably require higher export. What would be the most efficient way of setting up the project ? Keep in mind, there is no time to transcode, I am dealing with extremely short deadline.
    I looked around for a good, up-to-date Epic/Premiere CC workflow, but I am coming up empty. If anyone knows of one, I would certainly appreciate it.
    Thanks so much for your time,
    Lukas
    Andrea Hofmann replied 12 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Chris Borjis
    March 7, 2014 at 7:32 pm
  • Tim Kolb
    March 10, 2014 at 1:54 pm
    You can do any of the methods you propose…it’s a matter of what you want out to master.
    1. You can edit the footage full screen and then output to 1080, simply scaling (and or cropping as you wish) in the final export.
    This would allow you to master higher resolution files in 4K or UHD later and have the resolution to do it.
    2. You can create an HD sequence and edit the footage by placing the footage directly on the sequence…and you’d have lots of room to scale/crop, and generally recompose shots.
    This would limit you somewhat down the road if you ever wanted to export a 4K or UHD version as the master frame size is now HD unless you copy/paste all the edited material into a full-resolution sequence and then go back and undo and zoom/crop work that would show up as images that aren’t full frame.
    In either scenario, no up-front transcoding of the media would be required, and in the case of the RED metadata, you would be able to manipulate that information (for clips already in use on the timeline) right up to making the master exported version.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Lukas Dreser
    March 10, 2014 at 3:20 pm
    Tim,
    Great reply! Thank you so much for your time.
    I started organizing and syncing everything and I went with the 1080 timeline option. It’s good to know that I was pretty much on track with the approach.
    I am dealing with some additional issues now, mostly since there was no on board scratch audio recorded, I had to sync manually and use “merged clips”.
    The headache begins Everytime I either insert or overwrite a merged clip into the timeline from the source monitor, it un-links them. Not a biggie, just a hassle.
    The other issue is a bit more serious though, because i cannot access the “source settings” through the merged clips. Which hinders the workflow when we go to color (wanted to be in RedLog color space)….
    Maybe Adobe will release an update with that feature supported. We can only hope….
  • Tim Kolb
    March 10, 2014 at 3:37 pm
    The trick with “source settings” is that on a merged clip, PPro doesn’t automatically know which source you mean…there is more than one in a merged clip.
    You could work on a given R3D clip on a “scratch” timeline without the merged audio…and in theory, the metadata change should take place for each instance of that master clip…I would expect it to also apply to the merged clip.
    …just a thought.
    TimK,
    Kolb Productions,
  • Lukas Dreser
    March 10, 2014 at 4:21 pm
    Tim you would think that it would, but unfortunately it doesn’t update on the merged clip..:(
  • Lukas Dreser
    March 13, 2014 at 4:16 pm
    I came up with a workaround on the merged clips source settings for now.
    1. This works best with single video track.
    2. Export an EDL of your sequence, make sure the “use source file name” is checked.
    3. Import that EDL back into the project, it will import a folder into your project bin, open up the sequence inside
    4. All footage should be offline at this point, however the EDL pulled clips by their source file names, so after re-linking to the original media, highlight all clips on timeline, right-click – source settings, and voila
    Hopefully this helps somebody,
  • Andrea Hofmann
    July 22, 2014 at 11:34 am
    I’m a bit late on this thread ;), though I would love to know
    where in Premiere can you tick “use source file name” ?
    via EDL Export there isn’t unfortunately much to choose from…
    And another question @ Tim regarding what you mentioned about the
    format of the timeline:
    “… unless you copy/paste all the edited material into a full-resolution sequence and then go back and undo and zoom/crop work that would show up as images that aren’t full frame.”
    When will Premiere be able to convert the timeline format fairly easily? (e.g. as in “Offline” in HD and “Online” in 4K?)
    Thank you
    Kind Regards
    Andrea
