Activity › Forums › AJA Video Systems › Premiere CC recognizes AJA KONA LHe+ plugins but can not access the AJA settings / device offline
  • Premiere CC recognizes AJA KONA LHe+ plugins but can not access the AJA settings / device offline
    Posted by Greg Feir on April 2, 2014 at 6:06 pm
    Running Premiere CC. Installed the latest AJA KONA LHE+ Drivers and Adobe CC suite plug-ins successfully.
    (AJA KONA LHe Plus Hardware Driver v10.5.1 – Mac / AJA Plug-Ins for Adobe Creative Cloud – Mac v10.5)
    In the Project Set-up: Capture Device select drop down I am able to select the AJA Mov Capture or the AJA Sequence Capture, but if I try to access the AJA Settings nothing happens; the settings window does not appear, as if I had never clicked the button.
    Inside the project, when I open the capture window the “Device is Offline” (double checked connections) and I am still unable to access the settings.
    Anyone else with a similar issue or thoughts towards a solution?
    Thanks.
    Greg Feir replied 12 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
