Activity › Forums › Adobe Premiere Pro › Premiere CC not joining long AVCHD clips
  • Premiere CC not joining long AVCHD clips
    Posted by Tad Newberry on May 26, 2014 at 10:48 pm
    i’ve done a little googling on this with no luck so far, but will keep trying. i have two 1-hour clips that are only showing the first few minutes in PP CC. i suppose i’ll go back to ClipWrap if nothing else works.
    thanks for helping out a bonehead!
    __________________________
    FCS3 / Adobe CC
    3.33 GHz 6-Core Intel Xeon Mac Pro
    24GB RAM
    ATI Radeon HD 5870
    …and a few TeraBytes o’ storage
    (then it’s on to PetaBytes, ExaBytes and MosquitoBytes!)
    Tero Ahlfors replied 12 years, 4 months ago 4 Members · 4 Replies
  • Tero Ahlfors
    May 27, 2014 at 4:29 am
    Use the media browser tab to import them.
  • Jeff Pulera
    May 27, 2014 at 2:50 pm
    Hi Tad,
    To expand on Tero’s suggestion, it is important that you copy the entire contents of the SD card over to a folder on your hard drive – not just the video clips, but all folders, as important data is nested in them.
    Then in Premiere, import using “Media Browser” rather than File > Import. This should result in you seeing one long, seamless clip in Premiere rather than the shorter pieces as found on the SD card itself.
    This is the preferred method for AVCHD
    Jeff Pulera
    Safe Harbor Computers
  • Tad Newberry
    May 27, 2014 at 3:12 pm
    Thanks Tero and Jeff. Ya, i normally do “cmd-import” and everything works fine, but with these long puppies it’s different. I’d never used the Media Browser before….i tried it over the weekend just dragging the clips (via MB) to a timeline, but i got the same results. This morning, it worked! Not sure what i did different. Thanks for the tip. So, it still seems i can’t drag a folder of clips from MB into the Project folder, but i can drag individual (or groups of) clips. Anyway to keep the folder structure intact for organization? I have several folders of clips to bring in.
    FCS3 / Adobe CC
    24GB RAM
    ATI Radeon HD 5870
  • Steve Brame
    May 27, 2014 at 3:26 pm
    Use Prelude to ingest the media folders. It will keep everything intact for you.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
