Activity Forums Adobe Premiere Pro Premiere CC – FCP 7 Switcher Questions
  • Premiere CC – FCP 7 Switcher Questions
    Posted by Al Levine on June 18, 2013 at 6:42 am
    I’ve been editing with FCP Classic for over 10 years, staying up late tonight to dive into Premiere CC. Seeing if I can make this work for an animation/animatc workflow… (I edit for a few animated TV shows, as we bring in more editors we’re finding FCP 7 licenses are hard to come by!)
    I’m setting it up so (most) keyboard shortcuts work like they did in Final Cut 7. A few issues I can’t seem to figure out, maybe somebody has an answer?
    • One I use the pen tool to create keyframes on a clip, I cannot raise or lower the clip audio levels using a key command. Only when there aren’t any keyframes. In FCP, this didn’t matter.
    • Blading a Title does not create a new title clip. Any solutions besides duplicating the item in the bin? It’s much easier to blade a title in the timeline and modify a label. (Useful for labeling shot numbers in animation)
    • Scrub timeline without pitching up
    • Cannot match frame a freeze frame in the viewer, or change a freeze frame’s duration. Because I work in animation, I freeze frame quite a bit. In FCP 7, I would SHIFT+N to create a freeze frame, then drag out a duration.
    • Is there an easy way to see an audio clips volume without opening it up?
    Thanks! Sure I’ll have more as I figure this out.
    Ryan Aqu replied 12 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
