Activity › Forums › Adobe Premiere Pro › Premiere CC crashing on edit marker
Posted by Jeremy Mullen on October 1, 2013 at 3:52 pmGetting a ‘serious error’ crash over and over in Premiere CC, simply from trying to type comments into markers. After I type one, I go back to the source monitor to play forward and it’s done.
Started new fresh projects. Running the very latest CC update. Newest CUDA drivers for the NVIDIA NVIDIA GeForce GT 650M.
The project is tiny, only two clips in there right now, but it’s going to get a lot bigger. Need to fix this so I can log a lot of footage. Anyone have something similar?
Macbook Pro Retina Display – 2.3 GHz INtel Core i7 – 8 GB RAM – OS 10.7.5
Jeremiah Overman replied 11 years, 7 months ago 5 Members · 11 Replies -
Peter Garaway
October 1, 2013 at 8:39 pmHi Jeremy,
I’m not able to reproduce the crash here. Have you tried deleting your cache? To do so go to> /Users/[username]/Library/Application Support/Adobe/Common – Delete all of the folders there.
Have you thought about updating your OS? Premiere is most cases is much more stable in 10.8.X.
If that does’t work please let us know and we can try to come up with other solutions.
Best,
Peter Garaway
Adobe
Premiere Pro -
Jeremy Mullen
October 2, 2013 at 12:56 amDeleted the caches, still crashing out with a ‘serious error.’ I don’t have 10.8 available at the moment. And I’ve just finished a much longer-term more complex project using the same exact setup last week. The crashes just started as I’m logging this new project in.
Here’s the error log:
Process: Adobe Premiere Pro CC [3197]
Path: /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/MacOS/Adobe Premiere Pro CC
Identifier: com.adobe.AdobePremierePro
Version: 7.0.0 (7.0.0)
Code Type: X86-64 (Native)
Parent Process: launchd [177]Date/Time: 2013-10-01 20:54:29.493 -0400
OS Version: Mac OS X 10.7.5 (11G63b)
Report Version: 9Interval Since Last Report: 815084 sec
Crashes Since Last Report: 7
Per-App Interval Since Last Report: 40267 sec
Per-App Crashes Since Last Report: 7
Anonymous UUID: 80F805E9-30A5-4066-BF2C-BBEC8CACD7DBCrashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000001a0VM Regions Near 0x1a0:
__TEXT 0000000100000000-0000000100003000 [ 12K] r-x/rwx SM=COW /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/MacOS/Adobe Premiere Pro CCApplication Specific Information:
objc[3197]: garbage collection is OFFThread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.adobe.HandlerMarkerList.framework 0x000000010a936314 HandlerMarkerList::MarkerListPane::SetListenToMarkerChanges(bool) + 4
1 com.adobe.HandlerMarkerList.framework 0x000000010a92ba7a HandlerMarkerList::MarkerListItem::CommitEditChanges() + 410
2 com.adobe.HandlerMarkerList.framework 0x000000010a92f4d9 boost::detail::function::void_function_obj_invoker1::invoke(boost::detail::function::function_buffer&, dvaui::ui::MessageT*) + 105
3 com.adobe.dvaui.framework 0x0000000103b82ab2 dvaui::controls::UI_ControlView::SendValueChangedMessage() + 98
4 com.adobe.dvaui.framework 0x0000000103c8722b dvaui::controls::UI_TextEdit::TextMessageNotify(dvaui::controls::TextEditAction, dvaui::controls::OS_EditText*) + 955
5 com.adobe.dvaui.framework 0x0000000103b54111 dvaui::controls::OS_EditText::SendTextEditAction(dvaui::controls::TextEditAction) + 209
6 com.adobe.dvaui.framework 0x0000000103cda03c dvaui::controls::OS_EditTextItem_MAC::UI_FocusChanged(dvaui::ui::FocusChangeReason) + 140
7 com.adobe.dvaui.framework 0x0000000103d6b3fa dvaui::ui::UI_Node::UI_UpdateKeyboardFocusStateDueToLoss() + 362
8 com.adobe.dvaworkspace.framework 0x00000001066514df dvaworkspace::workspace::TopLevelWindow::UI_ActivationChanged(dvaui::ui::UI_Node::WindowActivation) + 31
9 com.adobe.dvacore.framework 0x00000001002a1a24 int dvacore::config::ErrorManager::ExecuteFunction(boost::function0*, void*) + 68
10 com.adobe.Frontend.framework 0x000000010006713c FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0) + 76
11 com.adobe.dvacore.framework 0x00000001002a1abc void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0, bool*) + 140
12 com.adobe.dvacore.framework 0x00000001002a362d void dvacore::config::ExecuteTopLevelFunction(boost::function0, bool*) + 125
13 com.adobe.dvaui.framework 0x0000000103de74f6 -[DVAMacWindowDelegate windowDidResignKey:] + 118
14 com.apple.Foundation 0x00007fff8373ad0e __-[NSNotificationCenter addObserver:selector:name:object:]_block_invoke_1 + 47
15 com.apple.CoreFoundation 0x00007fff8b8c87ba _CFXNotificationPost + 2634
16 com.apple.Foundation 0x00007fff83726fc3 -[NSNotificationCenter postNotificationName:object:userInfo:] + 65
17 com.apple.AppKit 0x00007fff8bf7b81d -[NSWindow resignKeyWindow] + 554
18 com.apple.AppKit 0x00007fff8c4022bc -[NSPanel resignKeyWindow] + 80
19 com.adobe.dvaui.framework 0x0000000103de5d0d -[DVAMacPanelWindow resignKeyWindow] + 109
20 com.apple.AppKit 0x00007fff8c0096b3 -[NSWindow _changeKeyAndMainLimitedOK:] + 655
21 com.apple.AppKit 0x00007fff8bfdc4c3 -[NSWindow sendEvent:] + 4301
22 com.apple.AppKit 0x00007fff8bf763a5 -[NSApplication sendEvent:] + 5593
23 com.adobe.dvaui.framework 0x0000000103de4a4e -[DVAMacApplication sendEvent:] + 622
24 com.adobe.Frontend.framework 0x00000001000bba27 -[PremiereCocoaMacApplication sendEvent:] + 311
25 com.apple.AppKit 0x00007fff8bf0ca0e -[NSApplication run] + 555
26 com.adobe.Frontend.framework 0x00000001000bd35d FE::MacApplication::RunSelf() + 45
27 com.adobe.Frontend.framework 0x00000001000458d6 FE::Application::Run(std::basic_string const&) + 6438
28 com.adobe.Frontend.framework 0x00000001000bea60 FE::AppMain(ASL::ObjectPtr const&, std::basic_string const&, int, void*) + 304
29 com.adobe.Frontend.framework 0x00000001000c50c2 FE::Run(ASL::ObjectPtr const&, std::basic_string const&, int) + 754
30 com.adobe.AdobePremierePro 0x0000000100001ae1 main + 625
31 com.adobe.AdobePremierePro 0x0000000100001864 start + 52Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff8adf47e6 kevent + 10
1 libdispatch.dylib 0x00007fff886ad786 _dispatch_mgr_invoke + 923
2 libdispatch.dylib 0x00007fff886ac316 _dispatch_mgr_thread + 54Thread 2:
1 com.adobe.dvatransport.framework 0x0000000100c81624 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue&) + 228
2 com.adobe.dvatransport.framework 0x0000000100c81214 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service::thread_info&, boost::asio::detail::op_queue&, boost::system::error_code const&) + 340
3 com.adobe.dvatransport.framework 0x0000000100c80ccd boost::asio::detail::task_io_service::run(boost::system::error_code&) + 285
4 com.adobe.dvatransport.framework 0x0000000100c71c92 SkyConnectionEnv::MainLoop() + 162
5 com.adobe.dvatransport.framework 0x0000000100c71879 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6 com.adobe.boost_threads.framework 0x00000001002496d4 thread_proxy + 164
7 libsystem_c.dylib 0x00007fff81f4c8bf _pthread_start + 335
8 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 3:
0 libsystem_kernel.dylib 0x00007fff8adf3bca __psynch_cvwait + 10
1 libsystem_c.dylib 0x00007fff81f50274 _pthread_cond_wait + 840
2 com.adobe.dvatransport.framework 0x0000000100c811dc boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service::thread_info&, boost::asio::detail::op_queue&, boost::system::error_code const&) + 284
4 com.adobe.dvatransport.framework 0x0000000100c80b9a boost::asio::detail::posix_thread::func::run() + 42
5 com.adobe.dvatransport.framework 0x0000000100c81b63 boost_asio_detail_posix_thread_function + 19
6 libsystem_c.dylib 0x00007fff81f4c8bf _pthread_start + 335
7 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 4:
2 com.apple.CoreServices.CarbonCore 0x00007fff84615a5e TSWaitOnCondition + 106
3 com.apple.CoreServices.CarbonCore 0x00007fff845a7ea6 TSWaitOnConditionTimedRelative + 127
4 com.apple.CoreServices.CarbonCore 0x00007fff845ece81 MPWaitOnQueue + 181
5 com.adobe.dvacore.framework 0x0000000100336bcb dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr&, int) + 171
6 com.adobe.dvacore.framework 0x0000000100334cbc dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 172
7 com.adobe.dvacore.framework 0x0000000100332329 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9function0IvEENS0_14ThreadPriorityERKNS4_8functionIFvvEEESE_ + 265
8 com.adobe.boost_threads.framework 0x00000001002496d4 thread_proxy + 164
9 libsystem_c.dylib 0x00007fff81f4c8bf _pthread_start + 335
10 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 5:
1 libsystem_c.dylib 0x00007fff81f502a6 _pthread_cond_wait + 890
2 com.apple.CoreServices.CarbonCore 0x00007fff845a7ec4 TSWaitOnConditionTimedRelative + 157
3 com.apple.CoreServices.CarbonCore 0x00007fff845ece81 MPWaitOnQueue + 181
4 com.adobe.dvacore.framework 0x0000000100336bcb dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr&, int) + 171
5 com.adobe.dvacore.framework 0x0000000100334cbc dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 172
6 com.adobe.dvacore.framework 0x0000000100332329 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9function0IvEENS0_14ThreadPriorityERKNS4_8functionIFvvEEESE_ + 265
7 com.adobe.boost_threads.framework 0x00000001002496d4 thread_proxy + 164
8 libsystem_c.dylib 0x00007fff81f4c8bf _pthread_start + 335
9 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 6:
10 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 7:
0 libsystem_kernel.dylib 0x00007fff8adf267a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8adf1d71 mach_msg + 73
2 libcuda_295.10.20.dylib 0x0000000118c11836 0x118a49000 + 1869878
3 libcuda_295.10.20.dylib 0x0000000118b6f2a7 0x118a49000 + 1204903
4 libcuda_295.10.20.dylib 0x0000000118c132b9 0x118a49000 + 1876665
5 libsystem_c.dylib 0x00007fff81f4c8bf _pthread_start + 335
6 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 8:
2 libclh.dylib 0x00007fff8b6b1166 cuosEventWait + 182
3 libclh.dylib 0x00007fff8b1c4927 intHandlerMain + 327
4 libclh.dylib 0x00007fff8b6b2229 cuosPosixThreadStartFunc + 41
6 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 9:
10 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 10:
2 com.apple.CoreFoundation 0x00007fff8b8ac50c __CFRunLoopServiceMachPort + 188
3 com.apple.CoreFoundation 0x00007fff8b8b4c74 __CFRunLoopRun + 1204
4 com.apple.CoreFoundation 0x00007fff8b8b4486 CFRunLoopRunSpecific + 230
5 com.apple.AVCVideoServices 0x000000011acf4a62 _ZN3AVSL27AVCVideoServicesThreadStartEPNS_28AVCVideoServicesThreadParamsE + 194
7 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 11:
7 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 12:
10 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 13:
9 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 14:
0 libsystem_kernel.dylib 0x00007fff8adf3e42 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff81f02dea nanosleep + 164
2 com.adobe.ScriptLayerPPro.framework 0x0000000106856548 ScObjects::Thread::wait(unsigned int) + 56
3 com.adobe.ScriptLayerPPro.framework 0x0000000106841a2e ScObjects::BridgeTalkThread::run() + 174
4 com.adobe.ScriptLayerPPro.framework 0x00000001068560e5 ScObjects::Thread::go(void*) + 165
6 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 15:
0 libsystem_kernel.dylib 0x00007fff8adf3d7a __recvfrom + 10
1 ServiceManager-Launcher.dylib 0x00000001231e0231 0x1231c8000 + 98865
2 ServiceManager-Launcher.dylib 0x00000001231df5d6 0x1231c8000 + 95702
3 ServiceManager-Launcher.dylib 0x00000001231de678 0x1231c8000 + 91768
4 ServiceManager-Launcher.dylib 0x00000001231de6e6 0x1231c8000 + 91878
5 ServiceManager-Launcher.dylib 0x00000001231d92e4 0x1231c8000 + 70372
6 ServiceManager-Launcher.dylib 0x00000001231d9cfe 0x1231c8000 + 72958
7 ServiceManager-Launcher.dylib 0x00000001231d9c0b 0x1231c8000 + 72715
8 ServiceManager-Launcher.dylib 0x00000001231dd36e 0x1231c8000 + 86894
9 ServiceManager-Launcher.dylib 0x00000001231dd4b2 0x1231c8000 + 87218
10 ServiceManager-Launcher.dylib 0x00000001231dd26d 0x1231c8000 + 86637
11 ServiceManager-Launcher.dylib 0x00000001231dd1e6 0x1231c8000 + 86502
12 ServiceManager-Launcher.dylib 0x00000001231cb916 0x1231c8000 + 14614
13 ServiceManager-Launcher.dylib 0x00000001231cfb05 0x1231c8000 + 31493
14 ServiceManager-Launcher.dylib 0x00000001231dde46 0x1231c8000 + 89670
15 ServiceManager-Launcher.dylib 0x00000001231dfef3 0x1231c8000 + 98035
16 libsystem_c.dylib 0x00007fff81f4c8bf _pthread_start + 335
17 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 16:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff8adf3df2 __select + 10
1 com.apple.CoreFoundation 0x00007fff8b8fdc8b __CFSocketManager + 1355
2 libsystem_c.dylib 0x00007fff81f4c8bf _pthread_start + 335
3 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 17:
0 libsystem_kernel.dylib 0x00007fff8adf4192 __workq_kernreturn + 10
1 libsystem_c.dylib 0x00007fff81f4e594 _pthread_wqthread + 758
2 libsystem_c.dylib 0x00007fff81f4fb85 start_wqthread + 13Thread 18:
2 com.apple.CoreServices.CarbonCore 0x00007fff84613c02 TS_exception_listener_thread + 100
3 libsystem_c.dylib 0x00007fff81f4c8bf _pthread_start + 335
4 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 19:
2 com.adobe.REDHandler.framework 0x000000012edec870 R3DSDK::kdu_thread_entity::process_jobs(R3DSDK::kdu_thread_queue*, bool, bool) + 2512
3 com.adobe.REDHandler.framework 0x000000012ededca7 R3DSDK::worker_startproc(void*) + 23
4 libsystem_c.dylib 0x00007fff81f4c8bf _pthread_start + 335
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 20:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 21:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 22:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 23:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 24:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 25:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 26:
2 com.mainconcept.mc.bc.dec.avc 0x00000001210e6d9d h264in_Video_GetAPIExt + 238429
3 com.mainconcept.mc.bc.dec.avc 0x000000012105f785 open_h264in_Video_stream + 341877
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 27:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 28:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 29:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 30:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 31:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 32:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 33:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 34:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x00007fff84b5eeb3 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, unsigned int) + 93
3 com.apple.audio.CoreAudio 0x00007fff84b5ef05 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 37
4 com.apple.audio.CoreAudio 0x00007fff84b58568 HALC_ProxyIOContext::IOWorkLoop() + 888
5 com.apple.audio.CoreAudio 0x00007fff84b58151 HALC_ProxyIOContext::IOThreadEntry(void*) + 73
6 com.apple.audio.CoreAudio 0x00007fff84b5800c HALB_IOThread::Entry(void*) + 78
8 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 35:
10 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 36:
2 libsystem_c.dylib 0x00007fff81f4fb85 start_wqthread + 13Thread 37:
2 libsystem_c.dylib 0x00007fff81f4fb85 start_wqthread + 13Thread 38:
2 libsystem_c.dylib 0x00007fff81f4fb85 start_wqthread + 13Thread 39:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 40:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 41:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 42:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 43:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 44:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 45:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 46:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 47:
2 libsystem_c.dylib 0x00007fff81f4fb85 start_wqthread + 13Thread 48:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 49:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 50:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 51:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 52:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 53:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 54:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 55:
5 libsystem_c.dylib 0x00007fff81f4fb75 thread_start + 13Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000000000000001d rbx: 0x0000000141044001 rcx: 0x0000000000000002 rdx: 0x000000012e2f9af0
rdi: 0x0000000000000000 rsi: 0x0000000000000001 rbp: 0x00007fff5fbfe770 rsp: 0x00007fff5fbfe770
r8: 0x0000000000000002 r9: 0x0000000141036470 r10: 0x00000000d8ccc3d1 r11: 0x0000000014dd1953
r12: 0x000000014102a5d0 r13: 0x000000014102a600 r14: 0x000000014102e300 r15: 0x0000000130037518
rip: 0x000000010a936314 rfl: 0x0000000000010202 cr2: 0x00000000000001a0
Logical CPU: 4Binary Images:
0x100000000 – 0x100002ff7 +com.adobe.AdobePremierePro (7.0.0 – 7.0.0) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/MacOS/Adobe Premiere Pro CC
0x10000a000 – 0x10000cfff +com.adobe.AdobeCrashReporter (7.0 – 7.0.1) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x100012000 – 0x100121fff +com.adobe.Frontend.framework (7.0.0 – 7.0.0.342) <2DB5F3E8-CEDA-3412-A437-5609D628BEA7> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
0x100225000 – 0x100225ff7 +com.adobe.PRM.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
0x10022b000 – 0x100231ff7 +com.adobe.boost_date_time.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x100248000 – 0x100256fff +com.adobe.boost_threads.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x10027a000 – 0x1004c4fff +com.adobe.dvacore.framework (7.0.0 – 7.0.0.342) <99A9FB2A-AF30-30B8-87D8-20460A7493A7> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x1006fb000 – 0x100729fff +com.adobe.dvamediatypes.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
0x10075d000 – 0x1007a7fff +com.adobe.ASLFoundation.framework (7.0.0 – 7.0.0.342) <7F14B0F8-2A1A-3857-A88F-C4DC4409D145> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
0x100812000 – 0x100861fff +com.adobe.headlights.LogSessionFramework (??? – 2.1.2.1756) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x100897000 – 0x100986fff +com.adobe.amtlib (7.0.0.169 – 7.0.0.169) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x100999000 – 0x100a06fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.5 -c 14 – 79.151805) <13002997-BD96-3A65-BFEC-09C9EB786A35> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x100a39000 – 0x100b45fff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 51 – 79.151805) <596FEA1A-3627-30B3-8AC4-BE1885788307> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
0x100bf3000 – 0x100c01fff +com.adobe.ASLMessaging.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
0x100c1c000 – 0x100c1dff7 +com.adobe.Memory.framework (7.0.0 – 7.0.0.342) <3DD6D38E-C1E1-38B3-80FA-D9E655C3C812> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
0x100c24000 – 0x100c32fff +com.adobe.ASLUnitTesting.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
0x100c4e000 – 0x100c52fff +com.adobe.boost_system.framework (7.0.0 – 7.0.0.342) <61691EF5-652D-39D6-825A-50207DF2E4AB> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x100c5b000 – 0x100cbcff7 +com.adobe.dvatransport.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
0x100d57000 – 0x100d7ffff +com.adobe.dvamarshal.framework (7.0.0 – 7.0.0.342) <137DE89C-0A15-39FA-9EAA-EDFD66E4C9F1> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
0x100dc8000 – 0x100fb9fff +com.adobe.dynamiclink.framework (7.0.0 – 7.0.0.342) <14F07DFC-4DBF-3A8D-99CC-83FA9F34DAA6> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
0x10121a000 – 0x10129cff7 +com.adobe.MediaFoundation.framework (7.0.0 – 7.0.0.342) <09B0FCB6-C95D-335B-88C4-B09F1D29E147> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
0x101353000 – 0x1013dbff7 +com.adobe.AudioRenderer.framework (7.0.0 – 7.0.0.342) <5DB2FE67-60FA-3A78-A92D-8F70116B4FD8> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
0x101499000 – 0x10155afff +com.adobe.dvacaptioning.framework (7.0.0 – 7.0.0.342) <89BFCAAC-C589-3560-8724-5059B71D4208> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
0x101612000 – 0x101669ff7 +com.adobe.dvatemporalxmp.framework (7.0.0 – 7.0.0.342) <66B24F39-E4AE-3E57-AEFF-B6779D3EC8B5> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
0x1016a2000 – 0x1016adfff +com.adobe.boost_signals.framework (7.0.0 – 7.0.0.342) <367C3258-FB9C-3722-A083-0D962ED535DC> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
0x1016c5000 – 0x10173aff7 +com.adobe.dvametadata.framework (7.0.0 – 7.0.0.342) <0FD5AD8F-EA69-3447-981A-69EEDB958772> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
0x1017f3000 – 0x10255fff7 +com.adobe.Backend.framework (7.0.0 – 7.0.0.342) <78B9CC6D-F8A0-37C9-81E6-CA5FF81FA0D7> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
0x1032ab000 – 0x1032e6ff7 +com.adobe.MLFoundation.framework (7.0.0 – 7.0.0.342) <4582CC27-2AC9-341E-866A-B31401835C5D> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
0x10334b000 – 0x103445fff +com.adobe.ImageRenderer.framework (7.0.0 – 7.0.0.342) <97B59A5A-D03E-3C17-B07D-7481C0D58B0C> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
0x1035dc000 – 0x103652fff +com.adobe.VideoFrame.framework (7.0.0 – 7.0.0.342) <215CEDB5-C73D-343F-BAE7-6C69C1B7F63A> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
0x1036d0000 – 0x103709ff7 +com.adobe.PluginSupport.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
0x103751000 – 0x10377afff +com.adobe.SweetPeaSupport.framework (7.0.0 – 7.0.0.342) <6FE1AB50-832A-34C6-9A94-08D817CE2498> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
0x1037bb000 – 0x103801fff +com.adobe.TransmitHost.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
0x103864000 – 0x10391bfef +com.adobe.atlaudio.framework (7.0.0 – 7.0.0.342) <45949F0E-AE83-3AE1-832F-7F37594A772B> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
0x103943000 – 0x10398aff7 +com.adobe.AudioSupport.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
0x1039dd000 – 0x1039dffff +com.adobe.MediaUtils.framework (7.0.0 – 7.0.0.342) <0AB1D0FA-15B0-3713-BAC4-D4E582C1E487> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
0x1039e7000 – 0x103a1aff7 +com.adobe.AudioFilterHost.framework (7.0.0 – 7.0.0.342) <11D6408B-9FC1-352C-B1A7-451A234067F7> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
0x103a68000 – 0x103aa8ff7 +com.adobe.AudioFilters.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
0x103b0a000 – 0x103f82fff +com.adobe.dvaui.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x10456f000 – 0x1047f2fff +com.adobe.UIFramework.framework (7.0.0 – 7.0.0.342) <1572F96E-B81F-310E-BA5F-E8443CD7D4F9> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
0x104b79000 – 0x104c84fff +com.adobe.VideoRenderer.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
0x104dd1000 – 0x104f4ffff +com.adobe.ImporterHost.framework (7.0.0 – 7.0.0.342) <9B3B7678-C709-365F-9B1B-6184CC19ACAB> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
0x1050f7000 – 0x1051ccff7 +com.adobe.ExporterHost.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
0x1052c0000 – 0x105332fff +com.adobe.PlayerHost.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
0x1053cb000 – 0x105434ff7 +com.adobe.RecorderHost.framework (7.0.0 – 7.0.0.342) <80B678FC-966B-328B-B2E8-B754B814465E> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
0x1054be000 – 0x1054cffff +com.adobe.ProjectConverterHost.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHost
0x1054f1000 – 0x1055d3ff7 +com.adobe.VideoFilterHost.framework (7.0.0 – 7.0.0.342) <07581626-195A-39F9-89B1-A2FF84250986> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
0x1056b9000 – 0x1056cdff7 +com.adobe.ProjectSupport.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
0x1056f7000 – 0x1057baff7 +com.adobe.AMEWrapper.framework (7.0.0 – 7.0.0.342) <872F557C-E64B-3ABF-8716-E301EB514C55> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
0x10586f000 – 0x10595efff +com.adobe.EncoderHost.framework (7.0.0 – 7.0.0.342) <8CE7768C-3030-33C6-BCE2-E5E1E0E2F909> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
0x105a61000 – 0x10611bff7 +com.adobe.Mezzanine.framework (7.0.0 – 7.0.0.342) <021F6FA2-8856-3C76-9D19-B7EC802EBA42> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
0x10660d000 – 0x1066bbff7 +com.adobe.dvaworkspace.framework (7.0.0 – 7.0.0.342) <43ED515D-B9F1-3756-8ED5-3171E832741D> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
0x1067c5000 – 0x1068bcfef +com.adobe.ScriptLayerPPro.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
0x1069b1000 – 0x106a6fff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.5 – 4.5.5.30707) <47137B86-90F2-3F47-A696-8C918A43BFC3> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x106abf000 – 0x106b6aff7 +com.adobe.AdobeScCore (ScCore 4.5.5 – 4.5.5.30707) <5EAD59E8-D05D-3E95-B1E0-4C96FF4329C9> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x106baf000 – 0x106d24ff7 +com.adobe.ScriptLayerPProQE.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ScriptLayerPProQE.framework/Versions/A/ScriptLayerPProQE
0x107006000 – 0x10709afff +com.adobe.PProDynamicLinkServer.framework (7.0.0 – 7.0.0.342) <883D6368-FE5A-3067-8662-FC739941D3CE> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkServer
0x1071d6000 – 0x107207ff7 +com.adobe.PrRegistration.framework (7.0.0 – 7.0.0.342) <4D45113D-E59F-306E-BE26-405AC6C00038> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PrRegistration.framework/Versions/A/PrRegistration
0x107239000 – 0x1072f5ff7 +com.adobe.dvaeve.framework (7.0.0 – 7.0.0.342) <5798D7E8-D0CC-3254-97F7-876D2C3D523F> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x107465000 – 0x1077b7ff7 +com.adobe.Dialogs.framework (7.0.0 – 7.0.0.342) <5444656C-0CAC-3043-98C0-240E523D4A5E> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
0x107afa000 – 0x107b4cff7 +com.adobe.BravoInitializer.framework (7.0.0 – 7.0.0.342) <3CDE5FB8-1782-39F4-9583-DEFB01334C22> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
0x107bc7000 – 0x107d0bfff +com.adobe.ACE (AdobeACE 2.20.02.30665 – 2.20.02.30665) <73C9699B-5EDC-3FDC-82FF-738C99AA840F> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x107d1e000 – 0x108051ff7 +com.adobe.AGM (AdobeAGM 4.30.18.30665 – 4.30.18.30665) <4E87DA88-AEE3-36A5-8A76-4DFA93F58BE8> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x1080bd000 – 0x1080dafff +com.adobe.BIB (AdobeBIB 1.2.03.30665 – 1.2.03.30665) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x1080e2000 – 0x1083f2ff7 +com.adobe.CoolType (AdobeCoolType 5.13.00.30665 – 5.13.00.30665) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x10843a000 – 0x108489fff +com.adobe.MediaCoreUI.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
0x1084f2000 – 0x1086aefff +com.adobe.SettingsUI.framework (7.0.0 – 7.0.0.342) <75B9EACA-272E-3E8E-9B1A-DE09FC12B7AF> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
0x1088e7000 – 0x108ae8fff +com.adobe.HSL.framework (7.0.0 – 7.0.0.342) <256FA596-5831-340F-BCF3-423FFAAD5C74> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
0x108d24000 – 0x108dd5fff +com.adobe.GPUFoundation.framework (7.0.0 – 7.0.0.342) <7A8CC68F-DEED-3E32-A92D-5A7BA1D0D59C> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
0x108e97000 – 0x108f59fff +com.adobe.exo.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x1090b1000 – 0x1090d1fff +com.adobe.CSXSManager.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
0x10910a000 – 0x109788fdf +com.adobe.PlugPlug (4.0.1.34 – 4.0.1.34) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x109d71000 – 0x109da3fff +com.adobe.HandlerAudioMiniMixer.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniMixer
0x109de7000 – 0x109e8cfff +com.adobe.HandlerAudioMixer.framework (7.0.0 – 7.0.0.342) <7F059859-8328-3288-9358-A016DF25576B> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
0x109f45000 – 0x109f9eff7 +com.adobe.HandlerAudioClipMixer.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerAudioClipMixer.framework/Versions/A/HandlerAudioClipMixer
0x10a01e000 – 0x10a073fff +com.adobe.HandlerCaptions.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerCaptions.framework/Versions/A/HandlerCaptions
0x10a0f2000 – 0x10a170ff7 +com.adobe.HandlerCapture.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
0x10a204000 – 0x10a246ff7 +com.adobe.HandlerEditToTape.framework (7.0.0 – 7.0.0.342) <26411487-41C4-3BF0-9175-9384ACE552CA> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerEditToTape.framework/Versions/A/HandlerEditToTape
0x10a2aa000 – 0x10a2d7ff7 +com.adobe.HandlerCSXS.framework (7.0.0 – 7.0.0.342) <649E6751-2781-3CB4-991B-5449BF6089B9> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
0x10a32f000 – 0x10a530fff +com.adobe.HandlerEffectControls.framework (7.0.0 – 7.0.0.342) <874763D8-473B-38EA-B3C8-045DD572E8D3> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectControls
0x10a6dd000 – 0x10a750fff +com.adobe.HandlerEffects.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
0x10a7de000 – 0x10a7e9fff +com.adobe.HandlerEvents.framework (7.0.0 – 7.0.0.342) <8809B635-69AB-3C33-98EF-953FEBD6BC59> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
0x10a80b000 – 0x10a81fff7 +com.adobe.HandlerGetProperties.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProperties
0x10a848000 – 0x10a85efff +com.adobe.HandlerHistory.framework (7.0.0 – 7.0.0.342) <7B0FC151-5F41-3891-8F31-513F1CA495AA> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
0x10a88c000 – 0x10a894ff7 +com.adobe.HandlerStoryPanel.framework (7.0.0 – 7.0.0.342) <187E1323-5C2D-33AB-BD2A-BA0A41766864> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerStoryPanel.framework/Versions/A/HandlerStoryPanel
0x10a8ab000 – 0x10a8d6ff7 +com.adobe.HandlerInfo.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
0x10a926000 – 0x10a952fff +com.adobe.HandlerMarkerList.framework (7.0.0 – 7.0.0.342) <71297FBB-365F-3A8D-8D3A-C2C30F8BCBA8> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerMarkerList.framework/Versions/A/HandlerMarkerList
0x10a9aa000 – 0x10a9fcfff +com.adobe.HandlerMetadataEditor.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataEditor
0x10aa83000 – 0x10aaa0ff7 +com.adobe.HandlerMediaBrowser.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowser
0x10aae1000 – 0x10aba9fff +com.adobe.HandlerProgramMonitor.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMonitor
0x10ac7a000 – 0x10ae14ff7 +com.adobe.HandlerProject.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
0x10afcc000 – 0x10b106ff7 +com.adobe.HandlerSourceMonitor.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMonitor
0x10b1e9000 – 0x10b1fcfff +com.adobe.HandlerTimecode.framework (7.0.0 – 7.0.0.342) <4585B227-92D0-3CCB-95C0-C81BBC0B6217> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerTimecode.framework/Versions/A/HandlerTimecode
0x10b224000 – 0x10b478fff +com.adobe.HandlerTimeline.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
0x10b66c000 – 0x10b6caff7 +com.adobe.FontEngine.framework (7.0.0 – 7.0.0.342) <4A696B2A-4693-3779-A66C-8C1555E8DB80> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
0x10b757000 – 0x10b773fff +com.adobe.TitleLayer.framework (7.0.0 – 7.0.0.342) <878B8CC8-90E1-34C4-B588-342ADCFC8C42> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
0x10b911000 – 0x10b91efff +com.adobe.TitleImageManager.framework (7.0.0 – 7.0.0.342) <77A39ED5-CCA7-3762-99F3-2F03EF64DA9E> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
0x10b939000 – 0x10b9b5ff7 +com.adobe.TitleCharacterFactory.framework (7.0.0 – 7.0.0.342) <7079D0E9-84F4-39C0-BB2F-CC22A1A4A2B7> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFactory
0x10ba15000 – 0x10baf9ff7 +com.adobe.TitleCG.framework (7.0.0 – 7.0.0.342) <0BA7EA44-4212-3245-A858-39A76125BD2C> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
0x10bb93000 – 0x10be1fff7 +com.adobe.TitleLayout.framework (7.0.0 – 7.0.0.342) <51FC635F-D558-357B-ADDD-6FF5A7929C49> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
0x10c3d3000 – 0x10c42ffff +com.adobe.TitleRenderer.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
0x10c4cb000 – 0x10cbabff7 +com.adobe.HandlerTitler.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
0x10d476000 – 0x10d5a4ff7 +com.winsoft.wrservices (WRServices 7.0.0 – 7.0.0) <9E3D7E52-958B-3907-BB4D-A3FD74A6A94B> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x10d5fd000 – 0x10d61fff7 +com.adobe.HandlerTools.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
0x10d667000 – 0x10d6a7ff7 +com.adobe.HandlerTrim.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerTrim.framework/Versions/A/HandlerTrim
0x10d6f7000 – 0x10d6fdfff +com.adobe.HandlerProgress.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks -
Peter Garaway
October 2, 2013 at 4:49 pmDoes this crash occur if the files are offline? If so can you upload your project for me to look at? Uploading to DropBox or something of the sort would be great.
Peter Garaway
Adobe
Premiere Pro -
Jeremy Mullen
October 2, 2013 at 10:49 pmI just tried it out with the files offline, just putting in test markers. Serious error. The project file is only 201 KB, so perhaps I can try and attach it to this post? Let’s see how that works-
Peter Garaway
October 2, 2013 at 11:09 pmHmmm don’t see anything attached.
Peter Garaway
Adobe
Premiere Pro -
Jeremy Mullen
October 2, 2013 at 11:14 pm -
Jeremy Mullen
October 6, 2013 at 8:08 pmI think I got the project file uploaded in the last post. Let me know if you still can’t get at it. In the meantime I’ve continued trying everything I can think of, including transcoding the MTS footage to Prores or other formats – still get the same crash, doing the same thing. Clicking between the source window and the markers window, as I play, pause, and type. I appreciate any help you can offer!
Jeremy Mullen
October 7, 2013 at 1:23 amAdditionally, I have now updated to 10.8 and just experienced the same crash. No change in Mountain Lion.
Here’s the latest log:
Process: Adobe Premiere Pro CC [760]
Parent Process: launchd [222]
User ID: 501Date/Time: 2013-10-06 21:21:31.855 -0400
OS Version: Mac OS X 10.8.5 (12F45)
Report Version: 10Interval Since Last Report: 356 sec
Crashes Since Last Report: 1
Per-App Interval Since Last Report: 283 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: 17B43F47-1E8A-2AB3-F04D-134F54D7AB1FCrashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Codes: EXC_I386_GPFLTThread 0 Crashed:: Dispatch queue: com.apple.main-thread
14 com.apple.CoreFoundation 0x00007fff95647eda _CFXNotificationPost + 2554
15 com.apple.Foundation 0x00007fff9383c7b6 -[NSNotificationCenter postNotificationName:object:userInfo:] + 64
16 com.apple.AppKit 0x00007fff901d7bcb -[NSWindow resignKeyWindow] + 572
17 com.apple.AppKit 0x00007fff8fec7544 -[NSPanel resignKeyWindow] + 82
18 com.adobe.dvaui.framework 0x0000000103de5d0d -[DVAMacPanelWindow resignKeyWindow] + 109
19 com.apple.AppKit 0x00007fff90067ee1 -[NSWindow _changeKeyAndMainLimitedOK:] + 684
20 com.apple.AppKit 0x00007fff90094088 -[NSWindow sendEvent:] + 5695
21 com.apple.AppKit 0x00007fff90090644 -[NSApplication sendEvent:] + 5761
22 com.adobe.dvaui.framework 0x0000000103de4a4e -[DVAMacApplication sendEvent:] + 622
23 com.adobe.Frontend.framework 0x00000001000bba27 -[PremiereCocoaMacApplication sendEvent:] + 311
24 com.apple.AppKit 0x00007fff8ffa621a -[NSApplication run] + 636
25 com.adobe.Frontend.framework 0x00000001000bd35d FE::MacApplication::RunSelf() + 45
26 com.adobe.Frontend.framework 0x00000001000458d6 FE::Application::Run(std::basic_string const&) + 6438
27 com.adobe.Frontend.framework 0x00000001000bea60 FE::AppMain(ASL::ObjectPtr const&, std::basic_string const&, int, void*) + 304
28 com.adobe.Frontend.framework 0x00000001000c50c2 FE::Run(ASL::ObjectPtr const&, std::basic_string const&, int) + 754
29 com.adobe.AdobePremierePro 0x0000000100001ae1 main + 625
30 com.adobe.AdobePremierePro 0x0000000100001864 start + 52Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff97f48d16 kevent + 10
1 libdispatch.dylib 0x00007fff91ae4dea _dispatch_mgr_invoke + 883
2 libdispatch.dylib 0x00007fff91ae49ee _dispatch_mgr_thread + 54Thread 2:
7 libsystem_c.dylib 0x00007fff96eb0772 _pthread_start + 327
8 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 3:
0 libsystem_kernel.dylib 0x00007fff97f480fa __psynch_cvwait + 10
1 libsystem_c.dylib 0x00007fff96eb4fb9 _pthread_cond_wait + 869
6 libsystem_c.dylib 0x00007fff96eb0772 _pthread_start + 327
7 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 4:
2 com.apple.CoreServices.CarbonCore 0x00007fff9a151210 TSWaitOnCondition + 108
3 com.apple.CoreServices.CarbonCore 0x00007fff9a1513e7 TSWaitOnConditionTimedRelative + 132
4 com.apple.CoreServices.CarbonCore 0x00007fff9a0b3a98 MPWaitOnQueue + 252
7 com.adobe.dvacore.framework 0x0000000100332329 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 265
9 libsystem_c.dylib 0x00007fff96eb0772 _pthread_start + 327
10 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 5:
1 libsystem_c.dylib 0x00007fff96eb4ff3 _pthread_cond_wait + 927
2 com.apple.CoreServices.CarbonCore 0x00007fff9a151406 TSWaitOnConditionTimedRelative + 163
3 com.apple.CoreServices.CarbonCore 0x00007fff9a0b3a98 MPWaitOnQueue + 252
6 com.adobe.dvacore.framework 0x0000000100332329 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 265
8 libsystem_c.dylib 0x00007fff96eb0772 _pthread_start + 327
9 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 6:
10 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 7:
0 libsystem_kernel.dylib 0x00007fff97f46686 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff97f45c42 mach_msg + 70
2 libcuda_310.40.00.10.dylib 0x000000011a652676 0x11a489000 + 1873526
3 libcuda_310.40.00.10.dylib 0x000000011a5afd97 0x11a489000 + 1207703
4 libcuda_310.40.00.10.dylib 0x000000011a6540f9 0x11a489000 + 1880313
5 libsystem_c.dylib 0x00007fff96eb0772 _pthread_start + 327
6 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 8:
2 libclh.dylib 0x00007fff9afa18c7 0x7fff9a98d000 + 6375623
3 libclh.dylib 0x00007fff9aa581d4 0x7fff9a98d000 + 831956
4 libclh.dylib 0x00007fff9afa2719 0x7fff9a98d000 + 6379289
6 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 9:
10 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 10:
2 com.apple.CoreFoundation 0x00007fff95632233 __CFRunLoopServiceMachPort + 195
3 com.apple.CoreFoundation 0x00007fff95637916 __CFRunLoopRun + 1078
4 com.apple.CoreFoundation 0x00007fff956370e2 CFRunLoopRunSpecific + 290
5 com.apple.AVCVideoServices 0x000000012b747a62 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 194
7 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 11:
7 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 12:
10 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 13:
9 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 14:
2 com.apple.CoreServices.CarbonCore 0x00007fff9a14e3dd TS_exception_listener_thread + 67
3 libsystem_c.dylib 0x00007fff96eb0772 _pthread_start + 327
4 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 15:
0 libsystem_kernel.dylib 0x00007fff97f48386 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff96f3a7c8 nanosleep + 163
6 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 16:
0 libsystem_kernel.dylib 0x00007fff97f482aa __recvfrom + 10
1 ServiceManager-Launcher.dylib 0x000000012329b231 0x123283000 + 98865
2 ServiceManager-Launcher.dylib 0x000000012329a5d6 0x123283000 + 95702
3 ServiceManager-Launcher.dylib 0x0000000123299678 0x123283000 + 91768
4 ServiceManager-Launcher.dylib 0x00000001232996e6 0x123283000 + 91878
5 ServiceManager-Launcher.dylib 0x00000001232942e4 0x123283000 + 70372
6 ServiceManager-Launcher.dylib 0x0000000123294cfe 0x123283000 + 72958
7 ServiceManager-Launcher.dylib 0x0000000123294c0b 0x123283000 + 72715
8 ServiceManager-Launcher.dylib 0x000000012329836e 0x123283000 + 86894
9 ServiceManager-Launcher.dylib 0x00000001232984b2 0x123283000 + 87218
10 ServiceManager-Launcher.dylib 0x000000012329826d 0x123283000 + 86637
11 ServiceManager-Launcher.dylib 0x00000001232981e6 0x123283000 + 86502
12 ServiceManager-Launcher.dylib 0x0000000123286916 0x123283000 + 14614
13 ServiceManager-Launcher.dylib 0x000000012328ab05 0x123283000 + 31493
14 ServiceManager-Launcher.dylib 0x0000000123298e46 0x123283000 + 89670
15 ServiceManager-Launcher.dylib 0x000000012329aef3 0x123283000 + 98035
16 libsystem_c.dylib 0x00007fff96eb0772 _pthread_start + 327
17 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 17:
2 com.adobe.REDHandler.framework 0x0000000126f52870 R3DSDK::kdu_thread_entity::process_jobs(R3DSDK::kdu_thread_queue*, bool, bool) + 2512
3 com.adobe.REDHandler.framework 0x0000000126f53ca7 R3DSDK::worker_startproc(void*) + 23
4 libsystem_c.dylib 0x00007fff96eb0772 _pthread_start + 327
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 18:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 19:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 20:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 21:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 22:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 23:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 24:
1 com.adobe.MediaFoundation.framework 0x000000010125e6d0 MF::DirectoryChangeMonitor::(anonymous namespace)::EventQueueThreadProc(void*) + 544
2 libsystem_c.dylib 0x00007fff96eb0772 _pthread_start + 327
3 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 25:
0 libsystem_kernel.dylib 0x00007fff97f486d6 __workq_kernreturn + 10
1 libsystem_c.dylib 0x00007fff96eb2f1c _pthread_workq_return + 25
2 libsystem_c.dylib 0x00007fff96eb2ce3 _pthread_wqthread + 412
3 libsystem_c.dylib 0x00007fff96e9d191 start_wqthread + 13Thread 26:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x00007fff91a2870c HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
3 com.apple.audio.CoreAudio 0x00007fff91a2869a HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4 com.apple.audio.CoreAudio 0x00007fff91a26ad9 HALC_ProxyIOContext::IOWorkLoop() + 1161
5 com.apple.audio.CoreAudio 0x00007fff91a265bf HALC_ProxyIOContext::IOThreadEntry(void*) + 83
6 com.apple.audio.CoreAudio 0x00007fff91a26497 HALB_IOThread::Entry(void*) + 75
8 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 27:
3 libsystem_c.dylib 0x00007fff96e9d191 start_wqthread + 13Thread 28:
10 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 29:
3 libsystem_c.dylib 0x00007fff96e9d191 start_wqthread + 13Thread 30:
2 com.mainconcept.mc.bc.dec.avc 0x000000012caf8d9d h264in_Video_GetAPIExt + 238429
3 com.mainconcept.mc.bc.dec.avc 0x000000012ca71785 open_h264in_Video_stream + 341877
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 31:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 32:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 33:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 34:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 35:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 36:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 37:
5 libsystem_c.dylib 0x00007fff96e9d1a1 thread_start + 13Thread 38:
3 libsystem_c.dylib 0x00007fff96e9d191 start_wqthread + 13Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000021 rbx: 0x0000000142945401 rcx: 0x0000000000000002 rdx: 0x00000000000a46b0
rdi: 0x6572502065626f64 rsi: 0x0000000000000001 rbp: 0x00007fff5fbfe800 rsp: 0x00007fff5fbfe800
r8: 0x0000000000000002 r9: 0x000000005a5327df r10: 0x0000000125ee22e0 r11: 0x000000007ce5453f
r12: 0x0000000123e66740 r13: 0x0000000123e66770 r14: 0x000000011201fe90 r15: 0x0000000111d32118
rip: 0x000000010a936314 rfl: 0x0000000000010202 cr2: 0x00000001109d3ab0
0x100812000 – 0x100861fff +com.adobe.headlights.LogSessionFramework (2.1.2.1756) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x10d6f7000 – 0x10d6fdfff +com.adobe.HandlerProgress.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerProgress.framework/Versions/A/HandlerProgress
0x10d70e000 – 0x10d7c6ff7 +com.adobe.dvaaudiofilterhost.framework (7.0.0 – 7.0.0.342) <57655213-3D5B-351E-B175-E636B08B2E58> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
0x10d8b2000 – 0x10d8feff7 +com.adobe.dvaaudiofilterhostui.framework (7.0.0 – 7.0.0.342) <53BDF6DA-3D23-38FE-9E23-C74ABF75258B> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhostui
0x10d997000 – 0x10d9b0ff7 +com.adobe.dvanet.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
0x10d9e9000 – 0x10dab6ff7 +com.adobe.dvanetsync.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
0x10dbe1000 – 0x10de1afff +com.adobe.EAClient.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
0x10e140000 – 0x10e2e5fff +com.adobe.EAPrBridge.framework (7.0.0 – 7.0.0.342) <1B679109-8D9C-38C7-8AFB-118F864AE0D1> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/EAPrBridge.framework/Versions/A/EAPrBridge
0x10e569000 – 0x10e59dff7 +com.adobe.dvacontrolsurfacehost.framework (7.0.0 – 7.0.0.342) <13188D67-A289-381F-B95F-B7E3240DF1D3> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurfacehost
0x10e614000 – 0x10e658ff7 +com.adobe.ControlSurface.framework (7.0.0 – 7.0.0.342) <8AF33576-116F-3A1A-90FB-E5A42441D04B> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ControlSurface.framework/Versions/A/ControlSurface
0x10e6bd000 – 0x10e995fe6 +libxerces-c-3.0.dylib (0) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/libxerces-c-3.0.dylib
0x10eb16000 – 0x10eb3afe7 +com.mainconcept.mc.enc.dv (9.6 – 9.6.8.7241) <40A96BB9-AAC7-CC6E-AAC3-B75F6407CF81> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
0x10eb4e000 – 0x10ebe9ff7 +com.adobe.boost_regex.framework (7.0.0 – 7.0.0.342) <4C580562-B008-3497-8206-19EF60AABE79> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
0x10ec80000 – 0x10ec92fff +com.adobe.boost_filesystem.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0x10ecb0000 – 0x10ecdefff com.apple.audio.CoreAudioKit (1.6.5 – 1.6.5) /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x10ecf9000 – 0x10ed38ff7 +com.adobe.dynamiclinkui.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
0x10edb1000 – 0x10ee19ff7 +com.adobe.QT32Client.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
0x10eebd000 – 0x10eec5fff +com.adobe.dvacaptioningui.framework (7.0.0 – 7.0.0.342) <9828B05E-32F6-36F4-864F-B040004E60C8> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvacaptioningui
0x10eed5000 – 0x10ef01ff7 +com.adobe.amefoundation.framework (7.0.0 – 7.0.0.0) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
0x10ef45000 – 0x10ef72fff +com.adobe.ameproperties.framework (7.0.0 – 7.0.0.0) <753EF30C-3F3F-3B6C-BF01-BF6189B1D5EB> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
0x10efbe000 – 0x10f00efff +com.adobe.DynamicLinkMedia.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
0x10f0b6000 – 0x10f0c9ff7 +com.adobe.ahclientframework (1.8.0.31 – 1.8.0.31) <58BB943C-98EC-3812-AAAB-74F66630D1D4> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x10f0d3000 – 0x10f218fff +com.adobe.dvametadataDB.framework (7.0.0 – 7.0.0.342) <955EA437-872C-3886-92E5-20A989AFA373> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
0x10f272000 – 0x10f32bfff +com.adobe.dvametadataUI.framework (7.0.0 – 7.0.0.342) <4662E81B-C695-3A4B-B5C4-62EFCB521818> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
0x10f433000 – 0x10f43ffff +com.adobe.dvamarkerUI.framework (7.0.0 – 7.0.0.342) <9DD3C96E-AC3B-37BC-A4CB-8F78D07266D7> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarkerUI
0x10f460000 – 0x10f486ff7 +com.adobe.dvastoryparser.framework (7.0.0 – 7.0.0.342) <4E519F89-40E6-38E5-82A5-F32EDBD2FC34> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
0x10f4b5000 – 0x10f51ffff +com.adobe.TimeWarpFilter.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/TimeWarpFilter.framework/Versions/A/TimeWarpFilter
0x10f591000 – 0x10f659fff +com.adobe.MBCProvider.framework (7.0.0 – 7.0.0.342) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
0x10f71f000 – 0x10f763ff7 +com.adobe.DisplaySurface.framework (7.0.0 – 7.0.0.342) <11300F46-FE77-3B7B-9C28-8A607953545E> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
0x10f7c4000 – 0x10f86ffff +com.diaquest.pro4.omf (1.0.0.1022 – 1.0.0.1022) <628D2DCB-CBF7-3B66-A77F-76BD7F101A56> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
0x10f896000 – 0x10f8bcfff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 – 1.1.01) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x10f8c4000 – 0x10f8c9fff com.apple.agl (3.2.1 – AGL-3.2.1) <57EC66DD-031A-3A8E-B067-72DB72B405E7> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x10f8d0000 – 0x10f8e6fff +com.adobe.AMEAppFoundation.framework (7.0.0 – 7.0.0.342) <3B55B7F5-8E18-3AD4-8658-EC5761D46ABC> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
0x10f914000 – 0x10f936ff7 +com.adobe.PostEncodeHost.framework (7.0.0 – 7.0.0.342) <36FD895C-9480-39EA-BADC-C905451CF24B> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
0x10f968000 – 0x10f96cff7 +com.adobe.ape.shim (3.4.0.29366 – 3. -
Tom Guiney
February 5, 2014 at 6:54 amDid this ever get solved? I’m having the same issue.
2GHZ Core i7 Macbook pro
os 10.9
premiere pro 7thanks
DP, gaffer, lighting product designer
convictionfilms.net
airboxlights.com -
Benjamin Shearn
August 27, 2014 at 4:57 amI’m having this exact problem. It’s excruciating! Has anyone found a resolution or workaround?
