Activity Forums Adobe Premiere Pro Premiere CC and RX3?
  • Premiere CC and RX3?
    Posted by Grayson Wasteland on August 7, 2014 at 4:41 pm
    I am using Premiere CC and have recently purchased iZotope RX3. However, I need help with the workflow.
    Here is my typical situation:
    • Ill shoot footage with a juiced link preamp directly into the camera so my audio and video are contained as one file and there is no need for matching audio up.
    • Then I subclip out everything I may want to use.
    • I take my subclips to the timeline and start putting together an edit.
    • I get that edit approved, but now need to clean up the audio.
    How do I go about editing the audio at this point?
    I can use RX3 as an AU unit in my tracks, but because the audio comes from different clips, it should not apply to a whole track. It would be nice if I could use an instance of RX3 on each clip, but I dont know if that is possible in Premiere and it may take up a lot of computing power. Also, because they are short snippets in the form of subclips, there isnt a lot of “empty space” for me to get a noise reduction reading.
    What I have been doing:
    • For each subclip, I find the raw footage file and create a new sequence with just that file.
    • Then I do my RX3 noise reduction via an AU component on the track.
    • Then I export this as “FILENAME-clean.mov.”
    • Then I change the name of the original footage to “FILENAME-original.mov”, which breaks the link.
    • When Premiere asks to locate the file, I point it to “FILENAME-clean.mov.”
    While this technically gets the job done, it is a lot of extra work. Especially since some of the raw footage files are very long and the subclip may only use a couple seconds from it. But, exporting that original footage as a new file with clean audio can take many many minutes.
    What is the real workflow on how to do this?
    Grayson Wasteland replied 12 years, 1 month ago 1 Member · 1 Reply
